17
I feel very stupid asking this question, because they're obviously different concepts, but I can't understand why. Every textbook I read has them both thoroughly explained, but at some point I can't grasp WHY they're different. Where do they defer?
Basically, what I can see is that in any Poisson process, if $N(t)$ is the amount of successes in a interval $[0,t)$, then $N(t_i)$ is independent of $N(t_j)$, $t_i$ and $t_j$ being sections of the interval, having the same length.
Besides, successes are distributed uniformly. The probability of a success does not depend on its position in the interval, but only its size.
I don't understand why those characteristics are not describing a Uniform distribution too. I mean, where is the line drawn?
Thank you very much for reading, and I'm sorry if you didn't understand something i said: English is not my prime language, and I acknowledge I have some problems using it.
FDrico
  • 199
  • Are you talking about a discrete uniform distribution or a continuous one? – Raskolnikov May 12 '13 at 20:23
  • Are you sure you mean a uniform distribution? I think you may mean a normal distribution. – xisk May 12 '13 at 20:26
  • Hm... continuous, i think.. Now i have my doubts, because i read somewhere that Poisson is discrete. I'm very confused – FDrico May 12 '13 at 20:27
  • I mean uniform, yes. – FDrico May 12 '13 at 20:28
    The Poisson distribution is indeed a discrete distribution, but I think your confusion seems to follow from the fact that what you describe are the properties of the Poisson process, not the distribution. – Raskolnikov May 12 '13 at 20:30
  • You're right. That was my main problem. Didn't know they were talking about two different thinks when they used process instead of distribution. Thank you!! – FDrico May 12 '13 at 20:39
Not a stupid question at all!
For a Poisson process, if one and only one event occurs in the interval between 0 and $t$, then the timing of when the event occurs is uniform between 0 and t. The total number of occurrences $N(t)$ is a Poisson random variable. It's when we "zoom in" and look at a single occurrence that we observe a uniform distribution (or an exponential distribution if we're interested in the waiting time instead of the time of the occurrence).
sol
  • 421
  • Thank you! I read your answer like 5 times, then i got it! Thank you very much! You can't imagine my happiness now! I've been reading books the whole week without beeing able to undestand, and i wasn't sure about asking the teacher because it would seem like i didn't understand anything in class. Thank you very very much! – FDrico May 12 '13 at 20:38
  • @FDrico I know that feeling too! Glad to help. – sol May 12 '13 at 20:40
  • Just to add up: if you throu up N points in a fixed space with uniform spatial distribution then the number of points in a small area is poisson distributed. There is the connection. – nadapez Jan 27 '23 at 01:15
The existing answer is good, but I will attempt a more precise one. This tutorial explains how a homogeneous Poisson process is similar to a set of $N$ draws from a uniform distribution and how they are different.
http://www.maths.qmul.ac.uk/~ig/MAS338/PP%20and%20uniform%20d-n.pdf
  • They're different because a size-$N$ sample from a uniform distribution has exactly $N$ points, whereas a homogeneous Poisson process can produce any number of points. The total number of points is (discretely) Poisson-distributed.
  • They're similar because if you sample the total number of points from a (discrete) Poisson distribution, and then sample their locations (aka arrival times) from $N$ iid uniform RV's, then the resulting point process is equivalent to a Poisson process sampled through any other method.
