This post is motivated by observing that certain operators have "fractional analogs".
For example, let $f: R\to R$ be a differentiable function.
The differential operator $D^{1}(f)$ produces a new function.
For positive integers $n\in N$, we can define the nth derivative: $D^{n}(f)\equiv D^{1}\circ D^{n-1}(f)$.
The half-derivative is defined to be the function $D^{\frac{1}{2}}(f)\equiv H(f)$ where $H\circ H(f)=D^{1}(f)$.
More generally, the qth derivative is defined $D^{q}(f)$ for $q \geq 0$.
Conveniently, this fractional derivative definition agrees w/ the usual definition when $q\in N$.
The goal of this post is to try to think about fractional operators more generally. That is many operator definitions $F^{n}(f)$ work for positive integers, but when are they extended?
\begin{array}{|l|l|l|l|} \hline \text{Operation} & \text{Discrete Index set} & \text{Continuum Index set} & \text{Note} \\ \hline % +(a,b) & \sum_{i \in I} f(i) & \int_{i \in I} f(i) di & \\ \hline % *(a,b) & \prod_{i \in I} f(i) & \exp\left( \int_{i \in I} \ln f(i) di \right) & \text{If A is a matrix } A^{1/2}\equiv\{M:M^2=A\} \\ \hline % & n!\equiv \underset{i\in{1,\dots,n}}{\prod i} & x!\equiv \Gamma(x+1) & \Gamma(n+1)=n! \text{ when n is a positive integer} \\ \hline % \circ(f,g) & f^{n}(x)\text{ , } n \in N & f^{a}(x)\text{ , } a \in R & f^{1/2}(x)\equiv\{g:g^2(x)=f(x)\} \\ \hline % D^{1}(f) & D^{n}(f)\text{ , } n \in N & D^{a}(f)\text{ , } a \in R_+ & D^{1/2}(f)\equiv\{g:D^2(g)=f\} \\ \hline % \end{array}
What are other known operations which can be extended/generalized in this way?
