I want to prove the following
Every $A$-module is projective if and only if $A$ is a finite direct product of fields.
I know a relevant result: Every ideal of a ring $A$ is generated by an idempotent if and only if $A$ is a finite direct of fields.
Thus it reduces to prove that:
Every $A$-module is projective if and only if every ideal of a ring $A$ is generated by an idempotent.
Assuming LHS of above, for any ideal $I$ of A, $A/I$ is projective as $A$ module hence flat as $A$ module, implying that $I=I^{2}$. How can I complete it ?
user371231
  • 2,481
While I agree with Angina Seng that going through the Wedderburn's theorem for not necessarily commutative rings is more conceptual (and the proof is less intricate), there is a way to prove what you want just in terms of commutative algebra:
For any ideal $I \subseteq R,$ the projection $R \rightarrow R/I$ splits by projectivity. That means, in particular, that there is a principal ideal $J \subseteq R$ (isomorphic to $R/I$ as an $R$-module, it is the image of the splitting map) such that $J\oplus I=R$. In particular, $I \simeq R/J$ as an $R$-module, so all ideals of $R$ are principal.
So now let us consider any ideal $I=xR$ of $R$. Then $I^2=I$ gives $x^2R=xR,$ so there is $r \in R$ such that $x^2r=x$. Then for any element $y=xs$ of $xR$, we have $(xr)\cdot(xs)=(x^2r)s=xs,$ and so in particular, for $s=r$ we have $(xr)^2=xr$. Finally, note that $I=xR \subseteq (xr)R \subseteq (x^2r)R \subseteq xR=I$, proving equality everywhere. This shows that $I=(xr)R$ is generated by an idempotent.
  • From my argument only thing I needed is that $I$ is finitely generated, which you have shown cleverly. BTW what’s about the other direction? Any hint will work. – user371231 Sep 04 '20 at 17:09
    You mean why every module over finite product of fields is projective? For example, just note that a module $M$ over a ring of the form $R_1 \times R_2 \times \dots \times R_k$ functorially decomposes as $e_1M \oplus e_2M \oplus \dots \oplus e_kM$ where $e_1+e_2+\dots +e_k=1$ is the decomposition of $1$ to the orthogonal idempotents, and each $e_iM$ is a $R_i$-module. Then it is easy to see that every short exact sequence over a ring that is a finite product of fields splits. – Pavel Čoupek Sep 04 '20 at 17:22
  • @PavelČoupek, I have one question. Does the result hold if $A$ is arbitrary product of fields instead of finite product ? I think not in general. Is there special cases (e.g., $A$ being Noetherian) where it is true ? – MAS Feb 22 '21 at 14:59
