In linear algebra, we define the polynomial ring as a set of series and then, define an addition and a multiplication which makes the set to a ring. With some homomorphisms, one reaches a structure which corresponds to the intuitive imagination of a set of polynomials.
But why does one not define $R[x]$ as a subset of functions with specific properties (e.g. define $1$ to be a polynomial and recursively, when $f, g$ are polynomials, $\alpha f$ ($\alpha \in R$) and $f + g$, $f \cdot g$ are polynomials). Why does one construct a new structure where one interprets a series as polynomial and has to define addition and multiplication on series explicitly? Where is the sense of doing so and not using the concept of a function?
Arctic Char
  • 16,007
ATW
  • 689
  • Which set of functions do you mean? Functions $f : R \to R$? – Paul Frost Aug 21 '20 at 13:12
  • @PaulFrost For example. Or let $\operatorname{dom}(f)$ be any $R$-algebra. Depends on what you want to plug in. – ATW Aug 21 '20 at 13:13
    This is important in the context of finite fields. For example, it is useful to distinguish between the polynomials $p(x) = x$ and $q(x) = x^3$, even though these two polynomials represent the same function over $\Bbb F_2$. – Ben Grossmann Aug 21 '20 at 13:14
    Think of $R$ finite. There are only finitely many functions $f: R\to R$, while $R[x]$ is infinite. – Arctic Char Aug 21 '20 at 13:15
    I think that for some rings (at least some finite ones), you could have distinct polynomials which produce the same function, e.g. $x^3 - x$ and $0$ over $Z_2$. That's not the most interesting example, but ... – Ned Aug 21 '20 at 13:16
  • @ATW Please make precise what the domain should be. Otherwise your question is too vague. – Paul Frost Aug 21 '20 at 13:17
    A polynomial is not a function from $R$ to $R$, albeit to each polynomial can be associated a function, but this is not necessarily a one-to-one correspondence. – Bernard Aug 21 '20 at 13:20
    When $R$ is an integral domain, often the next step after constructing the polynomial ring is to then construct it's field of fractions $R(x)$, i.e., the rational functions over $R$. If you wanted to treat these as functions, you wouldn't be able to do so by choosing some fixed domain beforehand, since different rational functions have different sets of poles. – halrankard Aug 21 '20 at 13:25
  • See the answers in the linked dupe (and the many other questions linked to that). – Bill Dubuque Aug 23 '20 at 22:28
One reason this is important is that we would like to be able to distinguish between polynomial that have different coefficients but correspond to the same function. This comes up in the context of finite fields: for example, it is useful to distinguish between the polynomials $p(x) = x$ and $q(x) = x^3$, even though these two polynomials represent the same function over $\Bbb F_2$.
Outside the motivation of studying polynomials in and of themselves, it is important that polynomials are "domain-agnostic." Even though we are thinking of polynomials with coefficients from a ring $R$, it is not necessarily the case that the associated function of interest takes elements of $R$ as its inputs. In particular, it is often useful that the same polynomial describes not only a function over $R$, but also a function over a ring-extension $\bar R$, or even a function over an $R$-Algebra $A$.
As an example from linear algebra: given a matrix $M \in \Bbb F^{n \times n}$ and a polynomial $p \in \Bbb F[x]$, it is highly useful to be able to talk about the application $p(M)$. However, this is nonsense if we define a polynomial to be a function with domain $\Bbb F$.
Ben Grossmann
  • 225,327
This is because different polynomials can lead to the same function.
For example, take a finite ring. Clearly on a finite ring, there are finitely many functions of one variable (more exactly, if the ring has $n$ elements, then there are exactly $n^n$ different functions). But there are infinitely many different polynomials (for every $n\in\mathbb N$, $x^n$ is a polynomial different from any $x^m, m\ne n$).
Moreover, the same polynomial can lead to different polynomial functions. For example, take polynomials over the real numbers. Then for any real algebra $A$, the polynomials lead to functions $f:A\to A$ obtained by replacing the variable by an instance of $A$. Clearly that is something you cannot achieve easily given just functions $f:\mathbb R\to\mathbb R$.
celtschk
  • 43,384
For this post, we will live in the realm of commutative rings with unit.
Suppose you have a ring $R$. Naively, a polynomial with coefficients in $R$ is something that takes something (usually called $x$) as an input and gives you something in return. Usually, this something is an element of $R$ and you get an element of $R$ in return, but it turns out that it is convenient to leave this without saying, so that a polynomial can take elements of some set and turn it into an element of this same set.
However, since polynomial expressions include sums and products, the "domain" of the polynomial cannot be any set: it should be a ring. Moreover, the coefficients of the polynomial are elements of $R$, so the "domain" cannot be any ring: it also has to be a ring in which makes sense to multiply by elements of $R$. Technically, if you have a ring $S$, the idea of multiplication by elements of $R$ is encoded in the form of a ring homomorphism $\phi:R\to S$. Then for any $r\in R$ and $s\in S$ we can define the product $rs$ as $rs=\phi(r)s$. Such a pair $(S,\phi)$ is called an $R$-algebra.
Finally, we want to be able to perform operations on the polynomials even before evaluating them, including multiplication by elements of $R$. This means that our set of polynomials needs to be a ring and an $R$-algebra as well. Moreover, for any element $s\in S$ and any polynomials $p,q$, we want $(p+q)(s)=p(s)+q(s)$ and $(pq)(s)=p(s)q(s)$: that is, we want the evaluation $p\mapsto p(s)$ to be a ring homomorphism that respects the $R$-multiplication. Hence we get the following idea of a definition:
Given a ring $R$, we want to have and $R$-algebra called the polynomial ring $R[x]$ that satisfies the following property: for any $R$-algebra $S$ (this is, a ring in which "multiplication by elements of $R$ makes sense") and any element $s\in S$, we have an evaluation map $\operatorname{ev}_s:R[x]\to S$ which is a ring homomorphism respecting the $R$-multiplication, such that the polynomial $x\in R[x]$ gets mapped to $s\in S$. Moreover, the evaluation homomorphism should be unique.
It turns out that the usual definition of $R[x]$ as some formal sums and products satisfies this definition; even more: this $R[x]$ is the unique (in a suitable sense) $R$-algebra satisfying the definition.
For the more abstractly minded people, this post means that for any $R$-algebra $S$ there is a one-one correspondence
$$\left\{\text{elements of $S$}\right\} \leftrightarrow \left\{ \overset{ \displaystyle\text{ring homomorphisms} } { \underset{\textstyle\text{respecting $R$-multiplication}} {R[x]\to S} } \right\}$$
And for you categorists, the upshot is that the polynomial ring $R$ is the free commutative $R$-algebra on the one-element set.
Jackozee Hakkiuz
  • 5,583
  • 35
