My professor said, if you remove identity element and self inverses, the number of elements of order two should be odd. So, in a group, the number of elements of order two can't be four.Why so?
Promona
  • 37
Preliminary remarks (motivated by bof's comment below). It is difficult to parse what you say your professor says for a few reasons. First, the identity of a group is its own inverse, so "identity and self-inverses" is redundant. Second, an element of a group is a self-inverse if and only if it is the identity or has order two. So if you "remove self-inverses" then there are no elements of order two left.
In any case, here are the facts:
Fact 1. If $G$ is a finite group of odd order, then $G$ has zero elements of order 2.
Fact 2. If $G$ is a finite group of even order, then $G$ has an odd number of elements of order 2.
Fact 3. If $G$ is an arbitrary group with a finite, but nonzero, number of elements of order 2, then $G$ has an odd number of elements of order 2.
So if we put it all together, we get the following description.
If $G$ is a group, then exactly one of the following holds.
  1. $G$ has no elements of order 2.
  2. $G$ has infinitely many elements of order 2.
  3. $G$ has an odd number of elements of order 2.
Note that Fact 3 generalizes Fact 2, if you assume the $p=2$ case of Cauchy's Theorem, which says that a finite group of even order has an element of order 2. However, the $p=2$ case of Cauchy's Theorem follows directly from Fact 2. So this justifies giving separate proofs of Facts 2 and 3.
So let's start the proofs.
Proof of Fact 1. This follows from Lagrange's Theorem, which implies that the order of an element in a finite group always divides the order of the group.
Proof of Fact 2. Partition $G$ into three pieces:
Piece 1: the identity element
Piece 2: the elements of order greater than 2
Piece 3: the elements of order 2
There are an even number of elements in piece 2 since every element in piece 2 can be paired with its inverse, which is also in piece 2 and is not equal to the original element. (Here we use the fact that $x=x^{-1}$ iff $x$ has order at most 2.)
So the total number of elements in pieces 1 and 2 is odd. Since $G$ has even order, the number of elements in piece 3 is also odd.
Proof of Fact 3. (See this question: the number of elements of order 2 in an infinite group. I will repeat the argument by Mikko Korhonen.)
Let $G$ be a group and let $X$ be the elements of order at most 2. Assume $G$ has an element $t$ of order 2 (so $t\in X$). Partition $X$ into two pieces. Piece 1 is the elements in $X$ that commute with $t$, and piece 2 is the rest. Then we can pair each $x$ in piece 1 with $xt$, and we can pair each $x$ in piece 2 with $txt^{-1}$. (One must check that this is a well-defined pairing, i.e., if $x$ is in piece 1 then $xt$ is in piece 1 and distinct from $x$; and if $x$ is in piece 2 then $txt^{-1}$ is in piece 2 and distinct from $x$.) So both pieces have an even number of elements, hence $X$ has an even number of elements. Removing the identity, we get an odd number of elements of order 2.
halrankard
  • 3,454
    @bof Yes, I must confess that I didn't fully read that part since it appeared that the question was about the number of elements of order 2. I can't see any other way of interpreting the question since, as you say, "self-inverse" and "order 2 or the identity" mean the same thing. There must be some miscommunication between the professor and student. – halrankard Aug 19 '20 at 15:09
    I suppose the question is about finite groups but it doesn't actually say "finite", so what happens with infinite groups? Can an infinite group have exactly two elements of order $2$? – bof Aug 19 '20 at 15:19
    @bof Good point (again!) It's answered here in the negative: https://math.stackexchange.com/questions/740397/the-number-of-elements-of-order-2-in-infinite-group (actually I think this deserves an edit to the answer again...sorry to keep doing this) – halrankard Aug 19 '20 at 15:22
