i'm looking for a non-continuous linear mapping f:$V \to \mathbb{R}$ with $V$ a normed linear space. I found that I needed to use a infinite-dimensional V because if V is finite-dimensional then f would automaticaly be continuous.
I maybe thought to this one: 1 if $x \le 0$ and 0 if $x>0$ but i'm not sure if i used that V is normed linear space.
As followed i wanted to prove that if f is continuous in zero that f is continuous overall. The implication of "f is continuous" from "f is continuous in zero" is trivial. But I'm not sure if i can prove the reverse implication because i don't understand the problem with the linear mapping, so i need some help there.
I also thought that if f is uniformly continuous that f is normal continuous and so on but the other implication needs a counter example. I'm just a little stuck that i need to work with linear mappings because i know the implication for a normal function. So maybe someone can help me understanding the connection between continuous and linear mappings?
Thanks a lot.
