I am currently looking at graphs which describe the movement of an object through spacetime. The graphs would look quite similar to Feynman Diagrams which describe the movement of some subatomic particle through spacetime. However, as you can see on a graph (or at least the kind which I am using), there are only 2 axes - often labelled as $\ x$ and $\ y$ - that represent a 2D plane. However - the spacial axis, $\ x$, can only represent 1 dimension. Therefore I would have to find a way to compress 3 spacial dimensions into 1. I will call this function $\ R$ and it will take the form $\ R(x,y,z)$ where $\ x,y$ and $\ z$ represent the 3 spacial dimensions of our universe.
But what about the movement of an object through space? I will represent this as a matrix where the first column is a vector of the "starting position" of the object, and the second column is a vector of the ending position. With this known, let our object start at position $\ \begin{bmatrix} 1 \\ 4 \\ 3\end{bmatrix}$ and move to position $\ \begin{bmatrix} 2 \\ 5 \\ 7 \end{bmatrix}$ over some time, $\ t$. We can represent this motion in the format: $$\ \begin{bmatrix} 1 & 2 \\ 4 & 5 \\ 3 & 7 \end{bmatrix}$$ This matrix represents the movement of an object through space, but not through time. We can set $\ t $ to some value, lets say "1". So now we have the movement of an object through space and a measure of the time it takes. But how would we compress this matrix into two numbers that are inherently 1 dimensional. We can do this with our $\ R$ function, but what is the $\ R$ function?
I tried using Eulers Number, $\ e$ to find this, and I tried the magnitude of both vectors added together and then put into a $\ \sqrt{}$ function, but I can't figure out how I would have a function which, for every input $\ x, y$ and $\ z$, would always give a different output for each input. Similar to: $$\ R(1,1,1) \neq R(1,1,1.000001) \neq R(1,1,1.000002)... $$
