-1
The motive behind this question is:
  1. In an ordered field LUB <=> IVT. Is the IVT equivalent to completeness?
  2. Connected Metric Space X does have IVP i.e "all continuous function f:M⟶R that admit a positive value and a negative value, also admit a c∈M such that f(c)=0". I read that the converse is also true. If M a metric space with the property of Intermediate Value. Show that M is connected.
So LUB <=> IVT <=> Connectedness (Is this correct?)
  1. Does the Complete Metric Space also have this property?
I am trying to find is a connection between Completion in Metric Space and Connectedness in Metric Space.
Also, Cauchy Completeness in R is weaker than LUB in R.(Cauchy Completion + Archimedian Property $\implies$ LUB)
So does Completion in $\mathbb{R}$ is stronger than Completion in Metric Spaces?
Basically I am trying to see the connections between all the the properties of Real Analysis and Metric Spaces.
Saikat
  • 1,583
There is no connection between completeness and connectedness. The middle-thirds Cantor set is complete in the usual metric and is zero-dimensional and hence totally disconnected. The irrationals are not complete in the usual metric, but they are a $G_\delta$-subset of the complete metric space $\Bbb R$, so there is a metric on them that generates the usual topology and in which they are complete. (Every $G_\delta$-set in a complete metric space is completely metrizable.)
Brian M. Scott
  • 616,228
