I come to ask for help building the exponential function as the solution to $y'=y$.
This question is different from :
Prove that $C\exp(x)$ is the only set of functions for which $f(x) = f'(x)$
Since I would like help to prove it using the following arguments :
- show that the solution should verify : $f(a+b)=f(a)f(b)$
- show that $f(x)$ for any $x$ in $\Bbb R$, will write $f(x)=c a^x$.
- show that if the function value is $1$ at $0$, using a numerical tool we will be able to find the Euler constant value and not it e.
For the moment here are my ideas :
- no idea – this is here that I need the more help
- prove it for naturals, rationals then all real numbers using density arguments.
- using Euler method,I can show that $a$ is the limit of $f(1) = \lim_{n\to\infty} (1+1/n)^n$ As you can see here, the computation will tend to $e$:
https://www.freecodecamp.org/news/eulers-method-explained-with-examples/
Many thanks, I'll appreciate your help
G
