Background: I'm searching for $_pF_q$ representations for MZVs. In related article On the interplay between hypergeometric series, Fourier-Legendre expansions and Euler sums by M. Cantarini and J. D’Aurizio, the series $_5F_4\left(\frac{1}{2},\frac{1}{2},\frac{1}{2},\frac{1}{2},\frac{1}{2};1,\frac{3}{2},\frac{3}{2},\frac{3}{2};1\right)$ is transformed to and Euler sum i.e. $\sum _{n=1}^{\infty } \frac{(-1)^n \left(\sum _{k=1}^n \frac{1}{2 k+1}\right){}^3}{2 n+1}$ by using FL expansion, which I invoke MZV values to give a closed-form successfully:
  • $ \pi \, _5F_4\left(\frac{1}{2},\frac{1}{2},\frac{1}{2},\frac{1}{2},\frac{1}{2};1,\frac{3}{2},\frac{3}{2},\frac{3}{2};1\right)=64 \Im(\text{Li}_4(1+i))-\frac{2}{3} \pi \log ^3(2)-\pi ^3 \log (2)-\frac{1}{32} \left(\psi ^{(3)}\left(\frac{1}{4}\right)-\psi ^{(3)}\left(\frac{3}{4}\right)\right)$
Problem: I wonder if the higher-weight case can be evaluated by similar means:
  • $ \pi \sum _{n=0}^{\infty } \left(\frac{\binom{2 n}{n}}{4^n}\right)^2\frac{1}{(2 n+1)^4}=\pi \, _6F_5\left(\frac{1}{2},\frac{1}{2},\frac{1}{2},\frac{1}{2},\frac{1}{2},\frac{1}{2};1,\frac{3}{2},\frac{3}{2},\frac{3}{2},\frac{3}{2};1\right)$
FL expansion of $\frac{\log ^3(x)}{\sqrt{x}}$ is needed here, but I'm not able to compute it.
Update: Using Jack's formula one may deduce
  • $\small \pi \, _6F_5\left(\frac{1}{2},\frac{1}{2},\frac{1}{2},\frac{1}{2},\frac{1}{2},\frac{1}{2};1,\frac{3}{2},\frac{3}{2},\frac{3}{2},\frac{3}{2};1\right)=-40 \Im(\text{CMZV}(4,\{4,1\},\{1,0\}))+\frac{152}{3} \Im(\text{CMZV}(4,\{4,1\},\{1,2\}))-256 \Im\left(\text{Li}_5\left(\frac{1}{2}+\frac{i}{2}\right)\right)+\frac{16}{3} \beta(4) \log (2)+\frac{25 \pi ^5}{64}+\frac{1}{6} \pi \log ^4(2)+\frac{3}{4} \pi ^3 \log ^2(2)$
See here for detailed expanlation.
Infiniticism
  • 8,644
  • 22
  • 67
    Wait for Jack :) – Ali Shadhar Jun 26 '20 at 06:55
    The FL-expansion of $\frac{\log^3(x)}{\sqrt{x}}$ can be computed by understanding the structure of the $n$-th derivatives and by invoking Rodrigues' formula. I also wrote that on paper, but I still cannot access my notes stored in my local Math Dept. Anyway you are right on principle, if you have a systematic way for dealing with Euler sums with weight $\leq 5$ you also have an explicit value for the first $\phantom{}_6 F_5$. – Jack D'Aurizio Jun 26 '20 at 13:46
  • The second $\phantom{}_6 F_5$ should be less troublesome by using the good ol' trick of writing $\frac{4^n}{\binom{2n}{n}}$ as a value of the Beta function. – Jack D'Aurizio Jun 26 '20 at 13:47
  • Maybe Marco Cantarini computed the FL of $\log^3(x)/\sqrt{x}$ on his own, I am going to summon him. – Jack D'Aurizio Jun 26 '20 at 13:48
  • Sorry, I need some clarification: I understand that MVZ means multiple zeta values, but what is FL? Also I would appreciate a link to the paper of Marco Cantarini, Jacopo D’Aurizio. Thanks in advance. – Dr. Wolfgang Hintze Jun 28 '20 at 06:55
    @Dr.WolfgangHintze FL means Fourier-Legenedre (expansion); you can find the mentioned paper here: https://link.springer.com/article/10.1007/s40574-019-00198-5 – Marco Cantarini Jun 28 '20 at 20:36
  • @Marco Cantarini Thank you for the information – Dr. Wolfgang Hintze Jun 29 '20 at 13:20
All right, I am going to re-do my computations from scratch. This will probably take some time, so please do not downvote this answer in the meanwhile. For any $n\geq 3$ we have $$ (-1)^{n+1}x^{n+1/2}\cdot \frac{d^n}{dx^n} \frac{\log^3(x)}{\sqrt{x}} = A_n+B_n\log(x)+C_n\log^2(x)+D_n\log^3(x)=S_n\tag{S}$$ with $A_n,B_n,C_n,D_n\in\mathbb{Q}$ related to each other by induction / recurrence relations. Once the explicit form of these constants is known we also have the explicit FL-expansion of $\frac{\log^3(x)}{\sqrt{x}}$ by Rodrigues formula, since
$$ \int_{0}^{1}\frac{\log^3(x)}{\sqrt{x}}P_n(2x-1)\,dx = \frac{1}{n!}\int_{0}^{1}x^n (1-x)^n \left[\frac{d^n}{dx^n}\frac{\log^3(x)}{\sqrt{x}}\right]\,dx \tag{B}$$ and the RHS is given by derivatives of the Beta function.
The coefficient which is the easiest to guess is $D_n$: $$ D_n = -\frac{1\cdot 3\cdot\ldots\cdot(2n-1)}{2^n} = -\frac{(2n)!}{4^n n!}$$ then we may differentiate both sides of $(S)$ and write down the induced recurrence relations.
$$ \left(n+\tfrac{1}{2}\right)S_n - S_{n+1} = B_n + 2C_n \log(x)+3D_n\log^2(x)\tag{R}$$ Focusing on the coefficient of $\log^2(x)$ on both sides we get $$ \left(n+\tfrac{1}{2}\right)C_n-C_{n+1} = 3D_n \tag{D_n}$$ and it is practical to introduce rescaled coefficients for simplifying the recursion.
Letting $D_n=\frac{(2n)!}{4^n n!}d_n$ (and the same for $A_n,B_n,C_n$) we get $$ \left(n+\tfrac{1}{2}\right)(c_n-c_{n+1}) = 3d_n = -3 $$ so $$ c_{n+1} = c_n+\frac{6}{2n+1} $$ and $$ C_n = \frac{(2n)!}{4^n n!}\cdot 6\sum_{k=0}^{n-1}\frac{1}{2k+1}.\tag{C_n}$$
[...] Continuing on this route, once we define $\mathscr{H}_n^{(k)}$ as $\sum_{h=0}^{n}\frac{1}{(2h+1)^k}$ we get
$$ \boxed{\small\frac{\log^3(x)}{\sqrt{x}}\stackrel{\mathcal{D}}{=}32\sum_{n\geq 0}(-1)^{n+1}P_n(2x-1)\left[4\mathscr{H}_n^3+2\mathscr{H}_n^{(3)}-\frac{6\mathscr{H}_n^2}{2n+1}+\frac{6\mathscr{H}_n}{(2n+1)^2}-\frac{3}{(2n+1)^3}\right]}.$$
Since $\sum_{n\geq 0}\left[\frac{1}{4^n}\binom{2n}{n}\right]^2\frac{1}{(2n+1)^4}$ can be represented in terms of $\frac{2}{\pi}\int_{0}^{1}\frac{\log^3(x)}{\sqrt{x}}K(x)\,dx $, the simple FL-expansion of $K(x)$ gives that the first hypergeometric series can be computed in terms of five Euler sums with weight five. The simplest of them are $$ \sum_{n\geq 0}\frac{(-1)^n}{(2n+1)^5} = \frac{5\pi^5}{1536}$$ and $$ \sum_{n\geq 0}\frac{(-1)^n\mathscr{H}_n}{(2n+1)^4}=-\frac{1}{96}\int_{0}^{1}\frac{\log^3(x)}{\sqrt{x}}\sum_{n\geq 0}(-1)^n\mathscr{H}_n x^n\,dx $$ which equals $$ -\frac{1}{96}\int_{0}^{1}\frac{\log^3(x)\arctan(x)}{x(1+x)}\,dx=\frac{5\pi^5}{24576}-\frac{1}{96}\int_{0}^{1}\frac{\log^3(x)\arctan(x)}{x+1}\,dx. $$ The factor $\frac{dx}{x+1}$ is invariant with respect to the substitution $x\to\frac{1-x}{1+x}$, so the last integral can also be expressed in terms of $\int_{0}^{1}\text{arctanh}^3(x)\left(\frac{\pi}{4}-\arctan x\right)\frac{dx}{x+1}$, where $$ \int_{0}^{1}\text{arctanh}^3(x)\frac{dx}{x+1}\,dx = \int_{0}^{+\infty}x^3(1-\tanh x)\,dx = \frac{7\pi^4}{960}$$ by the integral representations for the $\eta$ and $\zeta$ functions.
Jack D'Aurizio
  • 353,855
