Here is the problem statement:
A liquid is in the annular space between two vertical cylinders of radii $\kappa R$, $R$, and the liquid is open to the atmosphere at the top. Show that when the inner cylinder rotates with angular velocity $\Omega_i$ and the outer cylinder is fixed, the free liquid surface has the shape $$z_R -z = \frac{1}{2g}\frac{(\kappa^2R\Omega_i)^2}{(1-\kappa^2)^2}(\zeta^2 -4\log\zeta - \zeta^{-2})$$
where $z_R$ is the height of the fluid at the outer surface and $\zeta = \sigma/R$ ($\sigma$ is the radius in cylindrical coordinates).
Now I find the velocity field of the fluid to be given by: $$\vec{u} = \frac{\Omega_i}{1-\kappa}(\sigma - R^2/\sigma) \hat{\varphi} $$
Also, the flow is steady and incompressible, so Bernoulli's equation hold along each streamline. At the surface of the fluid the pressure is constant so we can take it to be zero. This then allows us to evaluate the constant for Bernoulli's equation along the outer wall to be $$ \frac{1}{2}u^2 + p/\rho + \chi = 0 + 0 + gz_R = gz_R$$ However, I'm not sure how I can proceed since this will not be the constant everywhere.
Enforce
  • 538
This problem pertains to viscous as opposed to inviscid flow and the Bernoulli equation is not relevant.
It is also assumed that the flow is steady and unidirectional with vanishing radial and axial velocity components, $u_r = u_z = 0$, and the azimuthal velocity component $u_\varphi(\sigma)$ is a function only of the radial coordinate $\sigma$.
In this case, the $\varphi$- component of the Navier-Stokes equations reduces to
$$\frac{1}{\sigma} \frac{\partial}{\partial \sigma}\left(\sigma \frac{\partial u_\varphi}{\partial \sigma} \right) - \frac{u_\varphi}{\sigma^2} = 0,$$
with general solution $a\sigma + b \sigma^{-1}$. The constants $a$ and $b$ are found by applying the boundary conditions $u_\varphi(R) = 0$ and $u_\varphi(\kappa R) = \Omega_i\kappa R$ yielding
$$ a = - \frac{\Omega_i \kappa^2}{1 - \kappa^2}, \,\,\, b = \frac{\Omega_i \kappa^2R^2}{1 - \kappa^2}, \,\,\,u_\varphi = - \frac{\Omega_i \kappa^2}{1 - \kappa^2}\left(\sigma - \frac{R^2}{\sigma} \right)$$
(You obtained the correct functional form for $u_\phi$ but the coefficient is incorrect -- which you will see by checking the boundary conditions.)
Introducing the dimensionless variable $\zeta = \sigma/R$ we obtain
$$u_\varphi = - \frac{ \kappa^2R\Omega_i}{1 - \kappa^2}\left(\zeta - \frac{1}{\zeta} \right)$$
Free Surface By symmetry the pressure field $p(\zeta,z)$ is independent of $\varphi$ and depends only of the radial coordinate $\zeta$ and the axial coordinate $z$.
The radial component of the Navier-Stokes equations reduces to a balance between the radial pressure gradient and the centripetal acceleration, given with $\zeta = \sigma/R$ by
$$\frac{\partial p}{\partial \zeta} = \frac{\rho u_\varphi^2}{\zeta}$$
Substituting for $u_\phi$ we get,
$$\frac{\partial p}{\partial \zeta} = \rho\frac{ (\kappa^2R\Omega_i)^2}{(1 - \kappa^2)^2}\left(\zeta - \frac{2}{\zeta} + \frac{1}{\zeta^3} \right),$$
and after integrating both sides,
$$p(\zeta,z) = \frac{\rho}{2}\frac{ (\kappa^2R\Omega_i)^2}{(1 - \kappa^2)^2}\left(\zeta^2 - 4 \log \zeta - \frac{1}{\zeta^2} \right) + C(z)$$
Here the integration constant $C(z)$ can depend on $z$.
The axial component of the Navier-Stokes equations reduces to $\frac{\partial p}{\partial z} = \rho g$ which implies that $C(z) = \rho g z + C_0$, and
$$p(\zeta,z) = \frac{\rho}{2}\frac{ (\kappa^2R\Omega_i)^2}{(1 - \kappa^2)^2}\left(\zeta^2 - 4 \log \zeta - \frac{1}{\zeta^2} \right) + \rho g z + C_0$$
At the outer cylinder we have $\zeta = 1$ and free surface height $Z_R$. Consequently,
$$p(1,z_R) = \rho gz_R + C_0 = p_A ,$$
where $p_A$ is atmospheric pressure. At a radial position $\zeta$ where the free surface height is $z_\zeta$ we also have atmospheric pressure. Hence,
$$p_A = p(\zeta,z_\zeta) = \frac{\rho}{2}\frac{ (\kappa^2R\Omega_i)^2}{(1 - \kappa^2)^2}\left(\zeta^2 - 4 \log \zeta - \frac{1}{\zeta^2} \right) + \rho g z + \underbrace{C_0}_{= p_A - \rho g z_R}$$
Eliminating $p_A$ from both sides and rearranging we get
$$z_R - z_\zeta = \frac{1}{2g}\frac{ (\kappa^2R\Omega_i)^2}{(1 - \kappa^2)^2}\left(\zeta^2 - 4 \log \zeta - \frac{1}{\zeta^2} \right) $$
RRL
  • 90,707
