Let $f(x)=\sin(x)x^2$. If you were to do integration by parts you would get:
$$\int \sin(x)x^2dx=\int\sin(x)dx\times x^2-\iint\sin(x)dx\times\frac{d}{dx}x^2dx$$
$$\int \sin(x)x^2dx=-\cos(x)x^2-\int-2\cos(x)xdx$$
$$\int\sin(x)x^2dx=-\cos(x)x^2+2(\int\cos(x)dx\times x-\iint\cos(x)dx\times\frac{d}{dx}xdx)$$
$$\int\sin(x)x^2dx=-\cos(x)x^2+2(\sin(x)x+\cos(x))+C$$
The part that I don't understand is why do we add the constant only at the end? For example, in row #$1$ you need to find the $\int \sin(x)dx$. We take it to be $-\cos(x)$ but in reality, it is $-\cos(x)+C_1$. If you were to compute this with $\int \sin(x)dx=-\cos(x)+C_1$, you would get the wrong result because $\int \sin(x)dx$ needs to be integrated again, and $C_1$ would turn in $x$, therefore you would get the wrong result. How do we know that $C_1=0$? I get that the solution will be correct that way, but why?
    When you look for antiderivatives, you just need ti find ONE of them. each of The others is obtained by adding some constant. – hamam_Abdallah Jun 10 '20 at 21:27
    i know but why do we use the one where $C_1$ is specifically $0$? –  Jun 10 '20 at 21:28
    To make things easier. If you want you can take $C_1=\ln(\pi+\sqrt{3})$. – hamam_Abdallah Jun 10 '20 at 21:29
  • but then you get an additional $x^2$ in the answer. If you were to take the derivative of that, you would get a completely separate function. –  Jun 10 '20 at 21:34
    If you take the integral of sin(x) to be -cos(x)+C1, you must do that in both parts of the integration by parts. The two terms involving C1 will then cancel. – Michael Cohen Jun 10 '20 at 21:36
    See https://math.stackexchange.com/questions/26869/constants-of-integration-in-integration-by-parts – Math2718 Jun 12 '20 at 00:38
The familiar formula for integration by parts is $$\int udv= uv-\int vdu $$
Now if you like to add a constant to your $v$ you get $$\int udv= u(v+c)-\int (v+c)du = uv+uc-\int vdu -c\int du = $$
$$uv+uc-\int vdu -cu = uv- \int vdu $$
Which is exactly the same result due to cancelation of $cu$ and -$cu$
Let's keep those $C_{i}$'s in those steps and show you that things still cancel out:
$$\int{x^{2}sinxdx}=-x^{2}cosx+C_{1}x^{2}-2C_{1}\int{xdx}+2\int{xcosxdx}$$
We get $$\int{x^{2}sinxdx}=-x^{2}cosx+C_{1}x^{2}-2C_{1}\int{xdx}+2xsinx+2C_{2}x-2\int{sinxdx}-2C_{2}\int{dx}$$
Then $$\int{x^{2}sinxdx}=-x^{2}cosx+C_{1}x^{2}-C_{1}(2)\frac{x^{2}}{2}+C_{3}+2xsinx+2xC_{2}+2cosx+C_{4}-2C_{2}x+C_{5}$$
Collection of like terms and letting $C=C_{3}+C_{4}+C_{5}$, we get $$\int{x^{2}sinxdx}=-x^{2}cosx+2xsinx+2cosx+C$$
Percy
  • 214
For $f $ and $ g$ $ C^1$ at some intervalle,
The integration by parts is based on the identity $$(fg)'=f'g + fg'$$
which yields to
$$\int f'g = fg - \int fg'$$
If you write
$$\int f'g = (f+C_1)g - \int fg'$$ the result will be false.
You should write
$$\int f'g = (f+C_1)g - \int (f+C_1)g'$$ To satisfy the first identity.
