Let $\lambda_n \in [0,1]$, and let $a_n \in (0,\frac{1}{4}),b_n \in [\frac{1}{4},\infty)$ satisfy the relation that the convex combination $$\lambda_n a_n+(1-\lambda_n)b_n=c > \frac{1}{4} \tag{1}$$ is a constant which does not depend on $n$.
Define $F:[0, \infty) \to \mathbb R$ by $$F(s) := \begin{cases} 1-2s, & \text{ if }\, s \le \frac{1}{4} \\ 2(\sqrt{s}-1)^2, & \text{ if }\, s \ge \frac{1}{4} \end{cases} $$
$F \in C^1$ is convex as its derivative $$F'(s)=\begin{cases} -2, & s\le\frac{1}{4}, \\ 2\left(1-\frac1{\sqrt{s}}\right), & s\geq\frac14 \end{cases}$$ is non-decreasing.
Now, suppose that $$ D_n:=F\big(\lambda_n a_n +(1-\lambda_n)b_n\big)-\lambda_nF(a_n)-(1-\lambda_n)F(b_n) \to 0 $$ when $n \to \infty$.
Question: I is true that $\lambda_n \to 0$?
There are two steps which needs to be done:
  1. Moving the estimate on the convexity gap into the strictly convex region $[1/4,\infty)$.
  2. Deducing that every convergent subsequence of $\lambda_n$ converges to $0$ or to $1$. (since $\lambda_n(1-\lambda_n)$ should be small-see strongly convex functions).
The constraint $(1)$ can be satisfied either when $\lambda_n \to 0$ or when $\lambda_n \to 1$. In the latter case, we must have $b_n \to \infty$.
This should imply that must have passed through a large region where $f$ is strongly convex, thus the convexity gap $D_n$ is large, which is a contradiction.
I think that there should be a (relatively) simple conceptual argument based on strong convexity properties of $F$ that establishes that. Note that $F$ is not twice differentiable at $\frac{1}{4}$, and that $\lim_{x \to \infty} F''(x)=0$, so $F$ becomes less convex when we get far away.
Asaf Shachar
  • 25,111
Let $\alpha_n\in (0,1)$ be such that $\alpha_n \frac{1}{4} + (1-\alpha_n) b_n = c$. We have $\alpha_n >\lambda_n$ and from convexity we have $$\lambda_n F(a_n) + (1-\lambda_n) F(b_n) \ge \alpha_n F(\frac{1}{4}) + (1-\alpha_n) F(b_n) \ge F(c).$$ It follows that the assumption $D_n\to 0$ implies that $\alpha_n F(\frac{1}{4}) + (1-\alpha_n) F(b_n) \to F(c)$. Since $\alpha_n > \lambda_n$, it is enough to prove that $\alpha_n \to 0$.
We first show that $b_n$ is bounded. Indeed, for $x>c$ let $\alpha(x) = \frac{x-c}{x-\frac{1}{4}}$, that is, $\alpha_n = \alpha(b_n)$. Define $$g(x) = \alpha F(\frac{1}{4}) + (1-\alpha)F(x).$$ The strict convexity of $F$ implies that $g$ is an increasing function of $x$, as can be seen from a quick drawing or by differentiating $g$ and using the fact that the strict convexity implies that $$F'(x) > \frac{F(x)-F(a)}{x-a}$$ for $x>a$. The fact that $g$ is increasing implies that $b_n$ must be bounded.
Once we have that $b_n$ is bounded, by compactness we can assume that $b_n\to b$, $\alpha_n \to \alpha$ and $$\alpha F(\frac{1}{4}) + (1-\alpha) F(b) \ge F(c) = F(\alpha \frac{1}{4} + (1-\alpha) b).$$ From the strict convexity of $F$ in $[1/4,\infty)$ and the fact that $c>1/4$, it follows that $\alpha = 0$ and $b=c$.
C M
  • 721
