I want to prove that every closed orientable surface is a Riemann surface i.e. every closed orientable surface admits a complex structure. Several proofs are available which make use of classification theorem for closed surfaces. How can one prove this without assuming the classification theorem?
Asked
Active
Viewed 291 times
Although this question asks only about the non-compact case, the accepted answer explicitly covers the compact case as well. – Lee Mosher May 29 '20 at 18:12
See also here: First, put a Riemannian metric on the surface, then use isothermal coordinates to define a holomorphic atlas. – Moishe Kohan May 29 '20 at 19:33
