I figured if I proved that $f'(x)=0$ then that would be it because, if first derivative is zero, than the function has constant value for every point of its domain. But I don't know how to prove that $f'(x)=0$ using given condition about limits. I thought about $\lim_{x\to\infty}(f(x)+f'(x))=\lim_{x\to\infty}f(x)+\lim_{x\to\infty}f'(x)$ but I failed to find out why is $\lim_{x\to\infty}f'(x)$ equal to zero.
It seems intuitive that $f'(x) = 0$ but how to prove it explicitly? – Nigruteen May 25 '20 at 19:11
Look at: https://math.stackexchange.com/questions/648652/if-lim-x-to-inftyfxfx-l-show-that-lim-x-to-infty-fx-l-and – user3669039 May 25 '20 at 19:23
Here is just a thought, so correct me if I'm wrong:
We can have 3 cases :
(i) $\lim_{x \to \infty} f'(x)>0$
Here it will imply the function is increasing even as we approach $\infty$, so as $x$ goes on increasing to a very large number, $f(x)$ will blow up to $\infty$
Thus, $\lim_{x \to \infty} f(x)+f'(x) = (something \ blowing \ to \ \infty) + (some \ positive) \neq c$
This can definitely not reach a constant $c \in \mathbb{R}$.
(ii) $\lim_{x \to \infty} f'(x)<0$
Similar to case (i), here $f(x)$ will blow down to $-\infty.$ Thus, $\lim_{x \to \infty} f(x) + f'(x) = (-\infty) + (some \ negative) \neq c \in \mathbb{R}$
(iii) The only case we are left with is $\lim_{x \to \infty} f'(x)=0$
We can see two sun-cases here:
(a) $$\lim_{x \to \infty} f(x)= c$$
checking this with the question it satisfies. So this is a valid answer.
(b) $$\lim_{x \to \infty} f(x)= \pm \infty$$
This would again not satisfy the condition of $\lim_{x \to \infty} f(x) +f'(x) = c$
So, I believe every possible case is accounted for, and only one case is satisfying the conditions, so
For $$\lim_{x \to \infty } f(x) + f'(x) = c \in \mathbb{R}$$
It is necessary that $\lim_{x \to \infty} f'(x) =0$ and $\lim_{x \to \infty}f(x)=c$
- 1,663
Yes. So is the $\sin$ function, but the limit of it's derivative does not exist. – Botond May 25 '20 at 19:39
@Botond if $\lim_{x \to \infty} f'(x)$ does not exist, then how can $\lim_{x \to \infty} f(x) +\lim_{x \to \infty} f'(x)$ be a definite constant? – Saket Gurjar May 25 '20 at 19:42
1If the limit of $g$ does not exist, we can still have that the limit of $f+g$ exists, but we can't separate the limit of the sum into a sum of limits. For example, take $f=\sin$, $g=-\sin$. But I'll think a little bit and see if I can come up with an example to my question. – Botond May 25 '20 at 19:45
@Botond I think I am getting your point, but then you'll have to either find a counter example or prove that there is no such $f(x)$. I'd say it has to be the latter because this seems to be a rather common question (see the reason for the close vote on the question), and such a flaw would have come up before. – Saket Gurjar May 25 '20 at 19:51
But again will have to come up with a mathematical argument to prove so. – Saket Gurjar May 25 '20 at 19:52
