Introduction
I'm reading "Advanced Integration Techniques" by Zaid Alyafeai, and he brings up quite a interesting example regarding Euler sums. The definition is different in the book and on WolramMathWorld, but in the book he defines Euler sums as infinite sums of the form:
$$S_p(r,n) = \sum_{k=1}^\infty \frac{(H_k^{(p)})^r}{k^n}$$
where $H_k^{(p)}$ is a generalized harmonic number. This is quite a general case so let's look at some more specific cases. Let $\vartheta(n)$
$$\vartheta(n) = S_1(1,n) = \sum_{k=1}^\infty \frac{(H_k^{(1)})^1}{k^q} = \sum_{k=1}^\infty \frac{H_k}{k^n}$$
The interesting example I talked about was that
$$\vartheta(2) = \sum_{k=1}^\infty \frac{H_k}{k^2} = 2\zeta(3)$$
I'm going to quickly derive this so you get the idea. Start by using the integral representation of the Harmonic numbers, so we get:
\begin{align} \sum_{k=1}^\infty \frac{H_k}{k^2} & = \int_0^1 \frac{1}{1-x}\sum_{k=1}^\infty \frac{1-x^k}{k^2} dx \\\\ & = \int_0^1 \frac{\zeta(2)-\operatorname{Li}_2(x)}{1-x} dx\end{align}
Here $\operatorname{Li}_2(x)$ is the Polylogarithm of second order. We now use one of the functional equations for $\operatorname{Li}_2(x)$ which states that
$$\zeta(2)-\operatorname{Li}_2(x) = \operatorname{Li}_2(1-x)+\ln(x)\ln(1-x)$$
Plugging that into the integral, we get
\begin{align} \int_0^1 \frac{\zeta(2)-\operatorname{Li}_2(x)}{1-x} dx & = \int_0^1 \frac{ \operatorname{Li}_2(1-x)+\ln(x)\ln(1-x)}{1-x} \\\\ & = \int_0^1 \frac{\operatorname{Li}_2(1-x)}{1-x} dx + \int_0^1 \frac{\ln(x)\ln(1-x)}{1-x} dx \\\\ & = \zeta(3) + \zeta(3) = 2\zeta(3)\end{align}
Now, because of this beautiful result, I started wondering what e.g. $\vartheta(3)$, $\vartheta(4)$ etc was and if there was a clean formula for the general case. I couldn't find any general formula for $\vartheta(n)$, but WolframAlpha gave many of the desired results (such as $\vartheta(3)$ and $\vartheta(4)$). I don't know about odd $n$, but if you try out higher even $n$ you see a very apparent pattern emerging. I claim that:
$$\vartheta(2n) = (n+1)\zeta(2n+1)-\sum_{k=1}^{n-1}\zeta(2k)\zeta(2n-2k+1)$$
You can check out for yourself with e.g. $\vartheta(50)$
It is also interesting to note that:
$$\lim_{n\to\infty}\vartheta(n)=1$$
Questions
  1. Is my formula of for $\vartheta(2n)$ correct?
  2. How do you prove cases when $n>2$? For example $\vartheta(3) = \frac{\pi^4}{72}$?
  3. Is there any other way than just numerically analyzing the answer to prove my formula?
  4. Is there a formula for odd $n$ or the complete general case (for all $n$)?
  • @r9m Oh wow, how didn't I find that question? Well, it's pretty much the same, so maybe you should just flag as a duplicate – Casimir Rönnlöf May 19 '20 at 18:31
  • @joriki Yes thank you, r9m already commented that ^ – Casimir Rönnlöf May 19 '20 at 18:32
  • That comment is generated automatically when you vote to close as a duplicate; I didn't write it. (In fact I was just about to edit it when you responded :-) (And, as you can see now, it's also automatically deleted again when the closure happens.) – joriki May 19 '20 at 18:32
