I was studying Multi-variable Calculus, and I got confused with the definition of the Gradient. The definition that I learned was this:
But, doing some examples, and searching in Google I saw that the Gradient vector can be normal to every tangent plane to the surface given. The picture below gives the tangent plane and the gradient vector normal to that tangent plane.
So, I got confused because I do not understand is the Gradient vector normal only to the level curves or also to other tangent planes? And if they are tangent to other planes, why there are a lot definition that define it differently?
Update:
Based on the comments what I understood was that a function of two variables has a level CURVE, and gradient is normal to that level curve. But, functions of three variables don’t have level curves but level SURFACES, that is why the gradient is normal to every point in that level surface. So, the second picture is the gradient vector normal at the level surface of some function with three variables. This is what I understood. If you believe that is not correct, than please provide with some explanation.
The sources for the 1st and 2nd pictures:
http://tutorial.math.lamar.edu/Classes/CalcIII/GradientVectorTangentPlane.aspx https://bvmtc.math.tamu.edu/~glahodny/Math251/Section%2012.6.pdf
