I just need a little bit of help verifying and finishing this problem off:
Show that $\mathbb{Q}(\sqrt{2+\sqrt{2}})/\mathbb{Q}$ is a Galois Extension, and determine the structure of the Galois group.
proof: Note that char$(\mathbb{Q})=0$, thus $\mathbb{Q}$ is perfect, that is, all irreducible polynomials in $\mathbb{Q}[x]$ are separable. Consider the polynomial $$p(x)=x^4-4x^2+2 \in \mathbb{Q}[x]$$ This is the minimal polynomial of $\sqrt{2+\sqrt{2}}$ over $\sqrt{2+\sqrt{2}}$. We also know that $$p(x)= \bigg(x-\sqrt{2+\sqrt{2}}\bigg)\bigg(x+\sqrt{2+\sqrt{2}}\bigg )\bigg(x+\sqrt{2-\sqrt{2}}\bigg)\bigg(x-\sqrt{2-\sqrt{2}}\bigg)$$ over $\mathbb{R}[x]$. So $p(x)$ is irredcible and has no repeated roots, i.e., $p(x)$ is separable. Now we show that $\mathbb{Q}(\sqrt{2+\sqrt{2}})$ is a splitting field over $\mathbb{R}$ for $p(x)\in \mathbb{Q}[x]$ in order to show that $\mathbb{Q}(\sqrt{2+\sqrt{2}})/\mathbb{Q}$ is a Galois Extension. Again for $$p(x)= \bigg(x-\sqrt{2+\sqrt{2}}\bigg)\bigg(x+\sqrt{2+\sqrt{2}}\bigg )\bigg(x+\sqrt{2-\sqrt{2}}\bigg)\bigg(x-\sqrt{2-\sqrt{2}}\bigg)$$ let $\alpha_1= \sqrt{2+\sqrt{2}}$, $\alpha_2=-\alpha_1$, $\alpha_3=\sqrt{2-\sqrt{2}}$ and $\alpha_4=-\alpha_3$. It is obvious that $\alpha_1,\alpha_2 \in \mathbb{Q}(\sqrt{2+\sqrt{2}})$. To show that $\alpha_3 \in \mathbb{Q}(\sqrt{2+\sqrt{2}})$, first consider $\alpha_3$ to be a element of $R$. Observe that $$\sqrt{2-\sqrt{2}}=\frac{\sqrt{2}\sqrt{2-\sqrt{2}}}{\sqrt{2}}=\frac{\sqrt{2}\sqrt{2-\sqrt{2}}}{\sqrt{2-\sqrt{2}}\sqrt{2+\sqrt{2}}}=\frac{\sqrt{2}}{\sqrt{2+\sqrt{2}}}$$ That is $\sqrt{2-\sqrt{2}}=\sqrt{2}(\sqrt{2+\sqrt{2}})^{-1}$. Since $\mathbb{Q}(\sqrt{2+\sqrt{2}})$ is a field, so we have that $\big((\sqrt{2+\sqrt{2}})^2-2\big)\in \mathbb{Q}(\sqrt{2+\sqrt{2}})$. However $$(\sqrt{2+\sqrt{2}})^2-2=\sqrt{2}$$ which means $\sqrt{2}\in \mathbb{Q}(\sqrt{2+\sqrt{2}})$. So $\sqrt{2-\sqrt{2}}=\sqrt{2}(\sqrt{2+\sqrt{2}})^{-1}\in \mathbb{Q}(\sqrt{2+\sqrt{2}})$ and $\alpha_i\in \mathbb{Q}(\sqrt{2+\sqrt{2}})$ for $i=1,..,4$. So $$\mathbb{Q}(\sqrt{2+\sqrt{2}})=\mathbb{Q}(\alpha_1, \alpha_2, \alpha_3, \alpha_4)$$ and so $\mathbb{Q}(\sqrt{2+\sqrt{2}})$ is a splitting field over $\mathbb{Q}$ for $p(x)$, hence $\mathbb{Q}(\sqrt{2+\sqrt{2}})/\mathbb{Q}$ is a Galois Extension.
For the seconed part Let $G=Gal(\mathbb{Q}(\sqrt{2+\sqrt{2}})/\mathbb{Q})$. We have that $|G|=[\mathbb{Q}(\sqrt{2+\sqrt{2}}):\mathbb{Q}]=4$.
This is everything I have up to now. I am very new to Galois Theory so guidance and help will be very beneficial to me. Also if you can let me know if my proof of the Galois Extension holds.
