Find the limit: $$\lim\limits_{n\to\infty} (\sqrt[3]{n^6-6n^4+1} - n^2)$$
I applied the identity: $$a^3 - b^3 = (a-b)(a^2+ab+b^2)$$ by multiplying the numerator and denominator by the complementary part.
$$\lim\limits_{n\to\infty} \frac{(\sqrt[3]{n^6-6n^4+1} - n^2)(\sqrt[3]{(n^6-6n^4+1)^2} + n^2\sqrt[3]{n^6-6n^4+1}+ n^4)}{(\sqrt[3]{(n^6-6n^4+1)^2} + n^2\sqrt[3]{n^6-6n^4+1}+ n^4)}=\lim\limits_{n\to\infty} \frac{n^6-6n^4+1 - n^6}{(\sqrt[3]{(n^6(1-6/n^2+1/n^6))^2} + n^2\sqrt[3]{n^6(1-6/n^2+1/n^6)}+ n^4)}=\lim\limits_{n\to\infty} \frac{-6n^4+1}{(n^4\sqrt[3]{(1-6/n^2+1/n^6)^2} + n^4\sqrt[3]{(1-6/n^2+1/n^6)}+ n^4)}=\lim\limits_{n\to\infty} \frac{-6+1/n^4}{(\sqrt[3]{(1-6/n^2+1/n^6)^2} + \sqrt[3]{(1-6/n^2+1/n^6)}+ 1)}=\frac{-6}{3}=-2$$
Is there any more elegant way to approach the problem?
YuiTo Cheng
  • 4,705
Makhayama
  • 171
    You may be interested in this post for a better understanding of how this trick works, when it works, and how to use it rigorously without needing knowledge of more powerful techniques such as asymptotic expansion. – user21820 Apr 03 '20 at 02:07
With binomial series, it's $$\lim\limits_{x\to\infty}\left[ n^2\left(1-\dfrac6{n^2}+\dfrac1{n^6}\right)^{1/3}-n^2\right]$$
$$\lim\limits_{x\to\infty}\left[ n^2\left(1-\dfrac13\dfrac6{n^2}+O\left(\dfrac1{n^4}\right)\right) -n^2\right]$$
$$=-2$$
J. W. Tanner
  • 60,406
A possible way is turning it into a derivative using $$n=\frac{1}{\sqrt t}$$
and consider $t\to 0^+$.
Hence,
$$\sqrt[3]{n^6-6n^4+1} - n^2 = \frac{\sqrt[3]{1-6t+t^3}-1}{t}$$ $$\stackrel{t\to 0^+}{\longrightarrow}\left.(\sqrt[3]{1-6t+t^3})'\right|_{t=0}=\frac{-6}{3}=-2$$
