Is the square root of $2$ divided by any integer (except zero), a rational or irrational number?
Dan Rust
  • 30,108
Siamoka
  • 159
Here is a thorough explanation.
Take an arbitrary integer $n\not=0$.
Then $\frac{n}{\sqrt{2}}$ is the desired expression.
Assume for sake of contradiction that $\frac{n}{\sqrt{2}}=\frac{p}{q}$ for relatively prime integers $p$ and $q$.
Square both sides.
$$\frac{n^2}{2}=\frac{p^2}{q^2}$$
Multiply both sides by $2q^2$.
$$n^2q^2=2p^2$$
So $2|n$ or $2|q$.
Case 1: Let $n=2k$ for positive $k$.
Then, $\frac{n}{\sqrt{2}}=k \sqrt{2}$ which is obviously irrational.
Case 2: Let $q=2a$ for integer $a$.
Then, $$4n^2a^2=2p^2$$
$$2n^2a^2=p^2$$
Hence $2|p$ which is a contradiction as we have assumed $p$ and $q$to be relatively prime.
Hence it will always be irrational.
This is VERY long-winded, but hopefully it will completely clear it up for you.
John Marty
  • 3,650
It is a irrational, as a irrational diveded by any integers (but 0) is still a irrational.
Paul
  • 20,553
