I've been doing a bit of study in number theory and modulo operations to prove certain things. This one in particular is a question I came across recently:
$$\text{Find the largest and smallest positive values of n for which} (n^{300}+100)\text{is divisible by} (n+10)$$
This is what I was able to come up with:
Take $d=n+10 \rightarrow n=d-10$
$\begin{align} n^{300}+100 &= (d-10)^{300} \\ &\equiv 10^{300}+100 \quad \bmod d \end{align}$
$\begin{align} 10^{300}+100 &= 10^2(10^{298}+1) \\ &= 100(100^{149}+1) \\ &= 100((101-1)^{149}+1) \end{align}$
So from 100 the smallest factor one can produce from d is 1, but that would lead to a negative value for n($-9$) which should probably also work but still.
The next one thus is 10 which gives $n=0$, something that could've been guessed from the beginning when you think about it. But I'm not entirely sure if 0 would be counted as a positive integer so I'd go for $20 \implies n=10$ and from the expression in brackets the $\bmod 101$ from both are -1 and 1 respectively so they cancel out. Thus the expression is divisible by 101.
The greatest factor you can produce then should be the greatest from $100$ and $100^{149}+1$ which is $101 \cdot 100 = 10100$
$n=10100-10=10090$
Am I right or can you still get a bigger factor? Or is my logic flawed at any step?
