How can we show that $x=2^k$ for some $k$ is equivalent (in the Naturals) to a $\Delta_0$ formula?
So, I'm stuck at showing that 'y divides x' and '2 divides y' are equivalent in the Naturals to $\Delta_0$ formulas.
Buddy Holly
  • 1,189
Obviously, $x > 1$ is a power of 2 iff (A): every $y > 1$ which divides $x$ is itself divisible by 2.
Use the fact that factors of a number are less than it to bound the quantifiers in formalizing statement (A), and you'll get a $\Delta_0$ wff.
Peter Smith
  • 54,743
  • could you please add the details here? I'm a bit unclear. – Buddy Holly Apr 11 '13 at 01:54
    No, I'm no going to add more details. If you don't know how to express divisibility by a $\Delta_0$ wff, don't know how to suitably bound the quantifiers in formalizing (A), then you need to go off to read some elementary texts before asking questions here. – Peter Smith Apr 11 '13 at 08:34
  • I didn't understand the way you did it. This should be done via induction as a starting, I assume – Buddy Holly Apr 11 '13 at 09:42
    No: induction has nothing to do with it. – Peter Smith Apr 11 '13 at 14:30
If $x=2^k$ then every prime number which divides $x$ has to be $2$. Of course that saying "every prime number" is an unbounded assertion, but luckily no prime number which is larger than $x$ can divide $x$, so we can instead write it as follows:
$x=2^k$ if and only if $x\neq 0$ and for every $p<x$, if $p$ is prime and $p\mid x$ then $p=2$.
Now we need to verify that "$k$ is a prime number" and $k\mid n$ are both bounded statement, but that's not very hard:
  1. Recall that $k\mid n$ if and only if there exists $m<n+1$ such that $k\cdot m=n$. Under this definition every number divides zero, and zero divides every number. Formally speaking we have the following bounded: $$k\mid n\iff\exists m<s(n):k\cdot m=n.$$
  2. Recall that $p$ is a prime if whenever $k<p$ and $k\mid p$ then $k=1$, but we also have that $0$ divides every number, so we actually have $p$ is a prime if $1<p$ and for every $k<p$, if $k\mid p$ then $k<2$. Again we have only one quantifier and it is bounded, so we have the following formula: $$p\text{ is prime} \iff s(0)<p\land\forall k<p:k\mid p\rightarrow k<s(s(0)).$$
So now to combine everything together we have as follows:
$$x=2^k\iff\lnot(x=0)\land\forall p<x:p\text{ is prime}\land p\mid x\rightarrow p=s(s(0)).$$
There is one quantifier which is bounded, over two formulas containing only bounded quantifiers themselves. Therefore the whole statement is bounded, that is to say $\Delta_0$.
Asaf Karagila
  • 393,674
