Consider integers $m,n$ and a $m \times m$-block Toeplitz matrix $A$ consisting of two different types of blocks as follows
\begin{align} A_{mn \times mn} &= \begin{bmatrix} B & C & C & \cdots & \cdots & C \\ C & B & C & C & \cdots & C \\ C & C & B & C & \ddots & \vdots \\ \vdots & \ddots & \ddots & \ddots & \ddots & C \\ C & \cdots & \cdots & C & B & C \\ C & \cdots & \cdots & \cdots & C & B \end{bmatrix} _{mn \times mn} , \end{align}
where $B$'s are diagonal blocks with $B=\frac{1}{m}I_n$ and $C$'s are multiples of the all-ones matrix $J_n$, specifically $C=\frac{1}{mn}J_n$.
I want to compute the eigenvalues of $A$ (I am mainly interested in the value of the 2nd largest eigenvalue since it has a special meaning in graph expansion applications).
Note that in my problem the following conditions also hold for $m,n$:
  • $m$ is odd.
  • $n$ is prime.
  • $m<n$.
I have experimented with such matrices on the computer and I have observed a trend for the spectrum of $A$ which consists of the following eigenvalues:
  • $\lambda_1=0$ with algebraic multiplicity $m-1$.
  • $\lambda_2=1/m$ with algebraic multiplicity $m(n-1)$.
  • $\lambda_3=1$ with algebraic multiplicity $1$.
I do not claim that this is necessarily the answer but at least it was consistent for the pairs of $m,n$ I tried.
Can you suggest how one can go and prove the above claim (if correct) or pinpoint other known results?
EDIT
After Omnomnomnom's note that \begin{equation} A = \frac 1{mn}\underbrace{\pmatrix{ 0&1&\cdots & 1\\ 1&0&\ddots&\vdots\\ \vdots&\ddots&\ddots&1\\ 1&\cdots&1&0}}_{= C_{m \times m}} \otimes J_n + \frac 1m I_{mn} \end{equation}
I did some computation of the spectrums of the individual matrices. First, the characteristic polynomial of the all-ones $J_n$ is $(\lambda-n)\lambda^{n-1}$ and hence its spectrum (with the multiplicities) is \begin{equation} \sigma(J_n)=\{(n,1),(0,n-1)\}. \end{equation} For $C$, assume that $\lambda_1,\dots,\lambda_m$ are its eigenvalues. By the facts that $\mathrm{det}(C-(-1)I_m)=det(J_m)=0$, $C\mathbf{1}_m=(m-1)\mathbf{1}_m$ and $\mathrm{trace}(C)=\sum_i\lambda_i=0$ it turns out that \begin{equation} \sigma(C)=\{(m-1,1),(-1,m-1)\}. \end{equation} Suppose that $\mu_1,\dots,\mu_n$ are the eigenvalues of $J_n$ then by the Kronecker product's properties the spectrum of $CJ_n$ consists of the pairwise products $\lambda_i\mu_j, \forall i,j$.
mgus
  • 1,371
Your observations are correct and hold for arbitrary $m,n$. It suffices to note that $$ A = \frac 1{mn}\pmatrix{ 0&1&\cdots & 1\\ 1&0&\ddots&\vdots\\ \vdots&\ddots&\ddots&1\\ 1&\cdots&1&0} \otimes J_n + \frac 1m I_{mn} $$ and use the properties of the Kronecker product.
In more detail: $C_{m \times m}$ is a rank 1 update of a scalar matrix, so we find that its eigenvalues are $-1$ with multiplicity $m-1$ and $m-1$ with multiplicity $1$. On the other hand, $J_n$ has eigenvalues $0$ with multiplicty $n-1$ and $n$ with multiplicity $1$.
It follows that $C \otimes J$ has eigenvalues $0$ with multiplicity $m(n-1)$, $-n$ with multiplicity $m-1$, and $n(m-1)$ with multiplicity $1$.
From there, it suffices to note that $\lambda$ is an eigenvalue of $A$ if and only if $c \lambda + d$ is an eigenvalue of $c A + dI$.
Ben Grossmann
  • 225,327
  • I have made some edits based on your response (please see edit). However, the resulting sum of the Kronecker product and the diagonal matrix confuses me. How can I proceed? – mgus Mar 05 '20 at 03:35
  • @mgus I'll add in what I had in mind when I have the chance – Ben Grossmann Mar 05 '20 at 10:08
  • See my latest edit – Ben Grossmann Mar 05 '20 at 14:21
  • Thanks for your response. Now it is clear to me except one thing: if the spectrums of $C$ and $J_n$ are indeed $\sigma(C)={(m-1,1),(-1,m-1)}$ and $\sigma(J_n)={(n,1),(0,n-1)}$, respectively then where is the eigenvalue $-n(m-1)$ of $C \otimes J$ is coming from? I thought it would be $n(m-1)$ with multiplicity $1$. After doing the remaining of the calculations for the eigenvalues of $A$ it seems that this should be true but how? Am I missing some plus or minus somewhere? – mgus Mar 05 '20 at 17:37
  • @mgus You're right about $n(m-1)$; I just had an extra minus sign there. – Ben Grossmann Mar 05 '20 at 17:39
  • But if this is the case, then the spectrum of $\frac{1}{mn}C \otimes J$ is ${(\frac{n(m-1)}{mn}, 1), (-1/m, m-1), (0, (n-1)m)}$ so adding $1/m$ to this spectrum yields all desired eigenvalues for $A$ except the eigenvalue $1$ – mgus Mar 05 '20 at 17:49
  • @mgus But we have $$ \frac{n(m-1)}{mn} + \frac 1m = \frac{mn - n}{mn} + \frac{n}{mn} = \frac{mn}{mn} = 1. $$ – Ben Grossmann Mar 05 '20 at 17:52
  • Ugh, thanks a lot for your help, had some typo in my notes. – mgus Mar 05 '20 at 17:56
