Let $x = (x_1,\ldots,x_p) \in \mathbb R^p$. I'm solving the constrained optimization problem
$$\begin{align*} \text{min} &\quad \sum_{i=1}^p (y_i-x_i)^2 \\ \text{s.t} &\quad \sum_{i=1}^p y_i - 1 &&=0\\ &\quad\forall i = \overline{1,p}: -y_i &&\le 0 \end{align*}$$
My attempt:
Let $f(y) = \sum_{i=1}^p (y_i-x_i)^2$, $h(y) = \sum_{i=1}^p y_i - 1$, and $g_i(y) = -y_i$ for all $i = \overline{1,p}$.
We have $f,g_i$ are convex and $h$ is linear. Let $\alpha =(1/p, \cdots, 1/p)$. Then $h(\alpha)=0$ and $g(\alpha) <0$ for all $i = \overline{1,p}$. It follows that Slater's condition is satisfied. By Karush-Kuhn-Tucker conditions, we have $$\begin{aligned} \begin{cases} \forall i = \overline{1,p}:\mu_i &\ge 0 \\ \forall i = \overline{1,p}: g_i(y) &\le 0\\ h(y) &=0 \\ \forall i = \overline{1,p}:\mu_i g_i(y)&=0 \\ \nabla f (y)+ \lambda\nabla h (y)+ \mu_i \nabla g_i (y) &=0 \end{cases} &\iff \begin{cases} \forall i = \overline{1,p}:\mu_i &\ge 0 \\ \forall i = \overline{1,p}:-y_i &\le 0\\ \sum_{i=1}^p y_i - 1&=0 \\ \forall i = \overline{1,p}: -\mu_i y_i &=0 \\ \forall i = \overline{1,p}: 2(y_i - x_i) +\lambda - \mu_i &= 0 \end{cases} \\ \end{aligned}$$
Then I'm stuck at solving the last system of equations.
How can I proceed to solve it? Thank you so much!
Akira
  • 17,367
Your problem can be rewritten as:
$$ \begin{alignat*}{3} \arg \min_{x} & \quad & \frac{1}{2} \left\| y - x \right\|_{2}^{2} \\ \text{subject to} & \quad & y \succeq 0 \\ & \quad & \boldsymbol{1}^{T} y = 1 \end{alignat*} $$
Then it is the exact problem as in Orthogonal Projection onto the Unit Simplex.
Royi
  • 8,711
  • Could you please explain the reasoning behind the trick is to leave non negativity constrain implicit? I'm unable to see how my KKT conditions is compatible/consistent with your solution. – Akira Feb 28 '20 at 10:25
  • I wanted to have a single parameter to apply the Newton Iteration on. Newton iteration is for unconstrained optimization so if I had $ \lambda $ it wouldn't fit for its non negativity. – Royi Feb 28 '20 at 10:35
  • I incorporated your ideas into my proof here. If you are interested, please have a look at it :) – Akira Feb 28 '20 at 17:42
  • Why would you open so many questions which are the same? – Royi Feb 28 '20 at 19:03
