I need help with understanding how to solve this task, because I'm a bit lost at the moment.
Use the powerseries $$f(x)=\frac{1}{1-x}$$ to decide the sum of the series
$\sum_{n=1}^{\infty} n(n+1)x^n$ and $\sum_{n=1}^{\infty} \frac{n(n+1)}{3^n}$
I don't understand how to manipulate the sums to use the power series of the function.
  • Hmm, I don't understand the "logic" when solving the task. So I didn't understand so much from that previous question. Should I not find a number and not only if the sum converge or diverge? – Mathomat55 Feb 25 '20 at 12:11
    The answer proves that$$\sum_{n=1}^\infty n(n+1)x^n=\frac{2x}{(1-x)^2}.$$What else do you want? – José Carlos Santos Feb 25 '20 at 12:14
  • Okay, I will read through again and see if I understand it ! – Mathomat55 Feb 25 '20 at 12:19
  • Okay, I have tried using the reasoning from link you sent me and tried to differentiate:
    $\frac{1}{1-x}=\sum_{n=0}^{\infty} x^n$
    But when I differentiate twice. I get
    $\frac{2}{(1-x)^3}=\sum_{n=0}^{\infty} n(n-1)x^{n-2}$
    So I don't get the answer in the link. Is this due to the summation index?
    – Mathomat55 Feb 25 '20 at 13:16
    No, you don't get $\sum_{n=0}^\infty n(n-1)x^{n-2}$. What you get is $\sum_{n=2}^\infty n(n-1)x^{n-2}$, which is equal to $\sum_{n=0}^\infty(n+2)(n+1)x^n$. – José Carlos Santos Feb 25 '20 at 13:40
  • Okay, I think I got it now. I'm sorry by the way. I'm a slow learner, so it takes some time for me to understand. But I really appreciate your help! But what do you think about what I have done now?
    So $\frac{2}{(1-x)^3}=\sum_{n=0}^{\infty} n(n-1)x^{n-2}$ and
    $\frac{2}{(1-x)^3}=\sum_{n=1}^{\infty} n(n+1)x^{n}x^{-1}$
    And then I multiply by x on each side and get
    $\frac{2x}{(1-x)^3}=\sum_{n=1}^{\infty} n(n+1)x^{n}$
    – Mathomat55 Feb 25 '20 at 13:52
    That is correct indeed. – José Carlos Santos Feb 25 '20 at 14:03
  • Thank you again for your help :) – Mathomat55 Feb 25 '20 at 14:11
First, note that for $|x| < 1$ we have $f(x) = \sum_{n=0}^\infty x^n$.
and for each $|r|<1$ the series converge uniformly in $[-r,r]$ so we can use "derivative term by term" to get:
$f'(x) = \sum_{n=0}^\infty nx^{n-1}$. Use this reasoning again to get
$f''(x) = \sum_{n=0}^\infty (n-1)nx^{n-2}$
Use this to calculate $\sum_n n(n+1)3^{-n}$
infinity
  • 946
