I have the following problem,
Show that $\lim\limits_{x \to 2} \bigg( 2^{x} \bigg)=4$ by finding a $\delta$ that guarantees that $2^{x}$ is within $\varepsilon$ of $4$ when $\varepsilon=0.01$
I want to prove that by using the epsilon delta proof, so I start as follows: \begin{align*} \left| f(x) - L \right| &< \varepsilon\\ \left| 2^{x} -4 \right| &< \varepsilon\ \end{align*}
but then I find myself completely confused... and I am also confused about the bit "guarantees that $2^{x}$ is within $\varepsilon$ of $4$ when $\varepsilon=0.01$", I am not sure what to do with $\varepsilon=0.01$.. I would really appreciate some help.. been stuck on this one for a while...
Friedrich
  • 487
You are trying to prove the following. For any given $\epsilon>0$, there exists $\delta>0$ such that when $0<|x-2|<\delta,$ it follows that $|2^x-4|<\epsilon$.
Consider when $x>2$. Since $2^x$ is increasing, $|2^x-4|=2^x-4$ so solving $2^x-4<\epsilon$, this holds iff $2^x<\epsilon+4$ iff $x<\log_2(\epsilon+4)$ iff $x-2<\log_2(\epsilon+4)-2$. The right hand side is positive since $\log_2(\epsilon+4)>\log_2(4)=2$. The if and only ifs allow you to go backwards in the proof. Therefore, for the right limit, it seems appropriate to choose $\delta_1=\log_2(\epsilon+4)-2$.
Now consider when $x<2$. Then it becomes $4-2^x<\epsilon$ iff $4-\epsilon<2^x$ iff $\log_2(4-\epsilon)<x$ iff $-\log_2(4-\epsilon)>-x$ iff $2-\log_2(4-\epsilon)>2-x$ . Thus, for the leftward limit, it seems that $\delta_2=2-\log_2(4-\epsilon)$ works.
For the combined limit, we want $0<|x-2|<\delta$. Choose $\delta=\min\{\delta_1,\delta_2\}$.
ProfOak
  • 5,915
