This is the problem statement:
You will be given two arrays of integers and asked to determine all integers that satisfy the following two conditions:
- The elements of the first array are all factors of the integer being considered
- The integer being considered is a factor of all elements of the second array
These numbers are referred to as being between the two arrays. You must determine how many such numbers exist.
I came across this while solving an 'easy' question in Hackerrank. Though it was easy to devise a brute force solution to this problem, I saw a very short solution in the discussions' section:
- Find the LCM of all the integers of array A.
- Find the GCD of all the integers of array B.
- Count the number of multiples of LCM that evenly divides the GCD.
This seems to work but I can't get my head around it. I want to understand that solution because it runs at a better time complexity. Could somebody please explain it?
Edit:
I know LCM and GCD. But I think I have lost all my intelligence in order to comprehend a simple solution in hand. I shall appreciate any intuition or instinct regarding this.
