I'm very stuck on this problem, which is an exercise from our course notes. Any clues or hints or a proof write up would be really helpful! Thanks!
Asked
Active
Viewed 88 times
-4
3What have you tried? – PrincessEev Feb 16 '20 at 03:57
3$x^{n+1}-y^{n+1}=(x+y)(x^n-y^n)-xy(x^{n-1}-y^{n-1})$ – J. W. Tanner Feb 16 '20 at 04:01
@EeveeTrainer tried rewriting $x^n$ as $k\cdot x$ per the definition of divisibility – user2793618 Feb 16 '20 at 04:15
@J.W.Tanner I'm confused as to how to factor (x-y) out of $x^{n-1}-y^{n-1}$ – user2793618 Feb 16 '20 at 04:22
You don't need to factor $x^{n+1}+y^{n+1}$ into $m\left(x^n+y^n\right)$, nor use only one base case. It is easier with J.W.'s method. – Jam Feb 16 '20 at 04:34
Base case: it's true for $n=0$ and $n=1$.
Induction step: assume it's true for $n-1$ and $n$;
i.e., $x^{n-1}-y^{n-1}$ and $x^n-y^n$ are divisible by $x-y$.
Then, since $x^{n+1}-y^{n+1}=(x+y)(x^n-y^n)-xy(x^{n-1}-y^{n-1})$,
it follows that $x^{n+1}-y^{n+1}$ is divisible by $x-y$.
J. W. Tanner
- 60,406
Would one base case work for this (assuming that we are using the IH of p(n))? Also I'm still confused as to how the factoring for $x-y$ out of $x^n-y^n$ works. – user2793618 Feb 16 '20 at 04:29
1I used two $n$ values for the base case so I could for the induction step; $x-y$ divides $x^n-y^n$ by the induction hypothesis – J. W. Tanner Feb 16 '20 at 04:33
That seems to almost be like strong induction, what if we just had the IH of p(n)? – user2793618 Feb 16 '20 at 04:35
Here's an answer with one $n$ value for the base case.
Induction step: it's true for $n=1$.
Now assume it's true for $n$; i.e., $x^{n}-y^{n}$ is divisible by $x-y$.
Since $x^{n+1}-y^{n+1}=x(x^{n}-y^{n})+y^{n}(x-y)$,
J. W. Tanner
- 60,406
But for this solution, if we had $n=0$ and the predicate to be defined as $x^{n-1}-y^{n-1}$, wouldn't this be invalid? – user2793618 Feb 16 '20 at 04:52
Compare $(x^{n+1}-y^{n+1})/(x-y) $ and $(x^n-y^n)/(x-y)$ using the answer for the other question – J. W. Tanner Feb 16 '20 at 05:13
