In the very beginning, I'm going to refer to an answer by @BillDubuque: https://math.stackexchange.com/a/48533/721644,
that motivated me to generalize my problem.
Instead of proving $\left(3+\sqrt{5}\right)^n+\left(3-\sqrt{5}\right)^n=2k,k\in\mathbb N$
I wanted to prove:
$\left(a+\sqrt{b}\right)^n+\left(a-\sqrt{b}\right)^n=2k,a,b,k\in\mathbb N, a>b$.
I haven't learned about groups yet. We have only mentioned them once or twice, so I wanted to stick to the given strong induction problem in a more abstract degree.
$(1)$ base case: $\tau(1)$ $$2a\in 2\mathbb N$$ $(2)$ assumption:
Let the statement $$\left(a+\sqrt{b}\right)^n+\left(a-\sqrt{b}\right)^n=2k,k\in\mathbb N$$
hold for some $\{1,\ldots,n\}$.
$(3)$ step: $\tau(n+1)$
\begin{equation}\left(a+\sqrt{b}\right)^{n+1}+\left(a-\sqrt{b}\right)^{n+1}=\left(a+\sqrt{b}\right)^n(a+\sqrt{b})+\left(a-\sqrt{b}\right)^n(a-\sqrt{b})\\a\underbrace{\left(\left(a+\sqrt{b}\right)^n+\left(a-\sqrt{b}\right)^n\right)}_{\in 2\mathbb N}+\sqrt{b}\left(\left(a+\sqrt{b}\right)^n-\left(a-\sqrt{b}\right)^n\right)\end{equation}
\begin{equation}\sqrt{b}\left(\left(a+\sqrt{b}\right)^n-\left(a-\sqrt{b}\right)^n\right)=2b\sum_{i=0}^{n-1}\left(a+\sqrt{b}\right)^{n-1-i}\left(a-\sqrt{b}\right)^i\\=2b\sum_{i=0}^{\left\lceil\frac{n}{2}\right\rceil\\}\underbrace{\left(\left(a+\sqrt{n}\right)^{n-1-2i}+\left(a-\sqrt{n}\right)^{n-1-2i}\right)}_{\in 2\mathbb N}(a^2-b)^i\end{equation}
Therefore, $\left(a+\sqrt{b}\right)^{n+1}\left(a-\sqrt{b}\right)^{n+1}\in 2\mathbb N$ and so is $\left(a+\sqrt{b}\right)^n+\left(a-\sqrt{b}\right)^n$.
Is this correct?
PinkyWay
  • 4,565
You can prove more using a bit of algebra.
$\mathbb{Z}[\sqrt b]$ is a ring of algebraic integers. Also, $\theta(a+\lambda \sqrt b)=a-\lambda \sqrt b$ where $a$, $\lambda$ $\in \mathbb{Z}$ defines an automorphism $\theta$ of $\mathbb{Z}[\sqrt b]$.
If $a$, $\lambda$ $\in \mathbb{Z}$ then $a+\lambda \sqrt b\in \mathbb{Z}[\sqrt b]$ and hence for $n\in \mathbb{Z_{>0}}$, $(a+\lambda \sqrt b)^n\in \mathbb{Z}[\sqrt b]$ and therefore $(a+\lambda \sqrt b)^n=A+\Lambda \sqrt b$ where $A$, $\Lambda$ $\in \mathbb{Z}$. Applying $\theta$ we also have $(a-\lambda \sqrt b)^n=A-\Lambda \sqrt b$ giving $$(a+\lambda \sqrt b)^n+(a-\lambda \sqrt b)^n=2A\in 2\mathbb{Z}.$$
where $\mathbb{Z}$ can be replaced by $\mathbb{N}$ if either $n$ is even or $a\in \mathbb{N}$.
Ivan
  • 770
  • This is essentially the same as the proof in my answer linked by the OP, except it strips the proof of the conceptual parity viewpoint - which was the raison d'etre of that presentation! – Bill Dubuque Feb 11 '20 at 17:31
  • @BillDubuque Actually I believe my argument is subtly different. You show that the expression is fixed by conjugation which implies it is in $\mathbb{Z}$ and then you use "parity" to show it is even. In contrast I simply compute the value directly as an even integer. – Ivan Feb 12 '20 at 00:18
  • The slight difference is by explicit design, i.e. my goal was to show how parity arguments extend to certain number rings. I chose not to repeat the above common proof since it had already been given here tens (if not hundreds) times already [see also here]. Hence the twist, which hopefully proves novel to some readers. – Bill Dubuque Feb 12 '20 at 00:52
Here is a different take, which I hope is instructive.
Let $x_n = \left(a+\sqrt{b}\right)^n+\left(a-\sqrt{b}\right)^n$.
Since $a+\sqrt{b}$ and $a-\sqrt{b}$ are roots of $x^2=2ax-(a^2-b)$, we have $x_{n+2}=2ax_{n+1}-(a^2-b)x_n$.
Therefore, if $x_n$ and $x_{n+1}$ are even, then so is $x_{n+2}$.
Thus, the result follows by induction because the base cases are easily checked:
$x_0=2$, $x_1=2a$, $x_2=2(a^2+b)$.
lhf
  • 216,483
