This is sort of a revival of this dead post but with a few tangential questions that I don't feel like I should coattail onto the linked post. Suppose we are trying to find an integral basis for $\mathbb{Q}[\alpha]$ where $\alpha^{3}-2 = 0$. We find that $d = \text{disc}(\lbrace 1, \alpha, \alpha^{2} \rbrace) = -108 = -2^{2}3^{3}$ and since this isn't squarefree, we have more work to do if we're to show $\lbrace 1, \alpha, \alpha^{2} \rbrace$ is an integral basis. So, we can use the result that $$ \mathbb{Z}[\alpha] \subset \mathcal{O}_{\mathbb{Q}[\alpha]} \subset d^{-1}\mathbb{Z}[\alpha]. $$ Now, what I'd like to do is to show that for any $\beta \in d^{-1}\mathbb{Z}[\alpha] \setminus \mathbb{Z}[\alpha]$ we have $\beta$ is not integral. As per the linked post, we should only verify that $\frac{1+\alpha+\alpha^{2}}{x}$ is not integral for $x=2,3$. First question: why are these the only elements that we need to check? It seems to me like we should check this for $\frac{a+b\alpha+c\alpha^{2}}{x}$ for $x | 2^{2}3^{3}$ and $a,b,c \in \mathbb{Z}$. On top of that, is there a clever way to compute the norm of a generic element of $d^{-1}\mathbb{Z}[\alpha]$ that I'm missing, because I don't know how I'd go about this.
Asked
Active
Viewed 304 times
Put $M = \mathbb{Z}[\alpha], K = \mathbb{Q}(\alpha)$, and let $d'$ be the discriminant of $\mathcal{O}{K}$. We have the following relation between $d$ and $d'$: $d = [\mathcal{O}{K}:M]^{2} \cdot d'$, so $[\mathcal{O}_{K}:M]$ must divide the largest possible square divisor of $-108$, namely $6$. As for computing the norm of a generic element, I don't know of any clever method, but a brute force approach is doable, and the result is not so bad. – Alex Wertheim Feb 05 '20 at 07:38
(You might also look at the following post: https://math.stackexchange.com/questions/99913/easy-way-to-show-that-mathbbz-sqrt32-is-the-ring-of-integers-of-mat. Dylan Moreland's answer makes the same observation that my comment does.) – Alex Wertheim Feb 05 '20 at 07:41
The ring of integers of a pure cubic field is entirely known, see e.g. https://math.stackexchange.com/a/3508522/300700 – nguyen quang do Feb 05 '20 at 17:37
