Let $R$ be a ring with unity $1$ and let $a,b\in R$ be not zero divisors. Is there any counterexample for: $$ab=1\quad\Rightarrow \quad ba=1$$
Assume $ab=1$ and $b$ is not a zero-divisor. Then $bab=b\cdot ab=b\cdot 1=b$, hence $(ba-1)b=0$, which implies $ba-1=0$ as $b$ is not a divisor of zero. Thus $ba=1$.
- 374,180
9Nice. So the lesson to take home is that non-zero-divisors can be canceled without needing an inverse. – hmakholm left over Monica Apr 06 '13 at 15:19
@Hagen von Eitzen I think your reasoning works for associative ring. What happens if the ring is not associative and not alternative? – Michael Rozenberg Jul 03 '19 at 04:56
If you drop the condition "no zero-divisors", there are counterexamples:
There are rings with elements which are left-invertible, but not right-invertible. Standard example: Consider a vector space $V$ with the countable infinite basis $\{v_1,v_2,\ldots\}$ and let $R$ be the endomorphism ring of $V$. Now the endomorphism $b$ induced by $v_1\mapsto v_2$, $v_2\mapsto v_3$, $v_3\mapsto v_4$ etc. is left-invertible, but not right-invertible. However, it is a right zero divisor in $R$.
(Explanation: I missed the condition "no zero-divisors" in the first place.)
- 22,696
@HenningMakholm: Right. But I missed the condition "no zero-divisors". So my counterexample is not correct. – azimut Apr 06 '13 at 15:14
@HenningMakholm I wonder what the correct answer to your question is :) However, I guess that these not right-invertible counterexamples fail at not being zero-divisors. – Hagen von Eitzen Apr 06 '13 at 15:14
Hint $\ $ Exploit conjugation $\rm\ \ 1\!-\!ba\, =\, b\, (1\!-\!ab)\, b^{-1}.\ $ [Multiply it by $\rm\:b\:$ to eliminate $\rm\:b^{-1}]$
Remark $\ $ To learn more about such look up "Dedekind finite" rings. You might also enjoy this tantalizing Halmos problem: explain why the following formal power series "proof" of the fact that if $\rm\:(1\!-\!ab)^{-1}\:$ exists then $\rm\:(1\!-\!ba)^{-1}\:$ exists, and has the value
$$\rm\begin{eqnarray} (1\!−\!ba)^{−1} &=&\rm 1+ba+b\color{#C00}{ab}a+b\color{#0A0}{abab}a+\ \cdots \\ &=&\rm 1+b(1\!+\,\color{#C00}{ab}\ \ \,+\ \ \color{#0A0}{abab}\ \ +\ \cdots)\,a\\ &=&\rm 1+b(1\!−\!ab)^{-1} a\end{eqnarray}$$
Thanks Math Gems . I have an answer . We have $1+bca=(1-ab)^{-1}$ with $c=(1-ba)^{-1}$. – Hung nguyen Apr 11 '13 at 15:09
We can give an automated proof of this result using Prover9. We input the ring axioms, and the assumption of $1$ and no zero divisors, and the goal $xy=1 \implies yx=1$ as follows:
formulas(assumptions).
(x + y) + z = x + (y + z). % + is associative
x + y = y + x. % + is commutative
x + 0 = x. % additive identity
0 + x = x.
x + -x = 0. % additive inverse
-x + x = 0.
x * (y + z) = (x * y) + (x * z). % distributivity
(x + y) * z = (x * z) + (y * z).
(x * y) * z = x * (y * z). % * is associative
x * 1 = x. % multiplicative identity
1 * x = x.
x * y = 0 -> (x = 0 | y = 0). % no zero divisors
end_of_list.
formulas(goals).
x * y = 1 -> y * x = 1.
end_of_list.
Here's the proof it generates:
============================== PROOF =================================
% Proof 1 at 0.03 (+ 0.01) seconds.
% Length of proof is 42.
% Level of proof is 11.
% Maximum clause weight is 17.
% Given clauses 87.
1 x * y = 0 -> x = 0 | y = 0 # label(non_clause). [assumption].
2 x * y = 1 -> y * x = 1 # label(non_clause) # label(goal). [goal].
3 (x + y) + z = x + (y + z). [assumption].
4 x + y = y + x. [assumption].
5 x + 0 = x. [assumption].
6 0 + x = x. [assumption].
7 x + -x = 0. [assumption].
9 x * (y + z) = (x * y) + (x * z). [assumption].
10 (x + y) * z = (x * z) + (y * z). [assumption].
11 (x * y) * z = x * (y * z). [assumption].
12 x * 1 = x. [assumption].
13 1 * x = x. [assumption].
14 x * y != 0 | 0 = x | 0 = y. [clausify(1)].
15 c1 * c2 = 1. [deny(2)].
16 1 = c1 * c2. [copy(15),flip(a)].
17 c2 * c1 != 1. [deny(2)].
18 c2 * c1 != c1 * c2. [copy(17),rewrite([16(4)])].
20 c1 * (c2 * x) = x. [back_rewrite(13),rewrite([16(1),11(4)])].
21 x * (c1 * c2) = x. [back_rewrite(12),rewrite([16(1)])].
22 x + (y + z) = y + (x + z). [para(4(a,1),3(a,1,1)),rewrite([3(2)])].
23 x + (-x + y) = y. [para(7(a,1),3(a,1,1)),rewrite([6(2)]),flip(a)].
27 (x * 0) + (x * y) = x * y. [para(6(a,1),9(a,1,2)),flip(a)].
28 (x * y) + (x * -y) = x * 0. [para(7(a,1),9(a,1,2)),flip(a)].
29 (x * y) + (0 * y) = x * y. [para(5(a,1),10(a,1,1)),flip(a)].
32 (x * y) + (x * z) != 0 | 0 = x | y + z = 0. [para(9(a,1),14(a,1)),flip(c)].
40 x + (y + -x) = y. [para(7(a,1),22(a,1,2)),rewrite([5(2)]),flip(a)].
42 --x = x. [para(7(a,1),23(a,1,2)),rewrite([5(2)]),flip(a)].
62 -x + (y + x) = y. [para(42(a,1),40(a,1,2,2))].
109 x * 0 = 0. [para(27(a,1),62(a,1,2)),rewrite([4(4),7(4)]),flip(a)].
111 (x * y) + (x * -y) = 0. [back_rewrite(28),rewrite([109(6)])].
112 x * (0 * y) = 0 * y. [para(109(a,1),11(a,1,1)),flip(a)].
131 -(x * -y) = x * y. [para(111(a,1),62(a,1,2)),rewrite([4(5),6(5)])].
135 x + (0 * (c2 * x)) = x. [para(20(a,1),29(a,1,1)),rewrite([20(9)])].
139 x * -y = -(x * y). [para(131(a,1),42(a,1,1)),flip(a)].
144 -(0 * (c2 * x)) = 0. [para(135(a,1),23(a,1,2)),rewrite([7(2),139(5),139(6)]),flip(a)].
147 -(0 * x) = 0. [para(112(a,1),144(a,1,1,2)),rewrite([112(4)])].
148 0 * x = 0. [para(147(a,1),7(a,1,2)),rewrite([4(4),6(4)])].
156 (c1 * x) + y != 0 | c1 = 0 | x + (c2 * y) = 0. [para(20(a,1),32(a,1,2)),flip(b)].
321 c1 = 0 | x + -(c2 * (c1 * x)) = 0. [resolve(156,a,40,a),rewrite([6(9),139(8)])].
354 c1 = 0 | c2 * (c1 * x) = x. [para(321(b,1),23(a,1,2)),rewrite([5(5),139(7),139(8),42(9)]),flip(b)].
368 c1 = 0. [para(21(a,1),354(b,1,2)),unit_del(b,18)].
380 $F. [back_rewrite(18),rewrite([368(2),109(3),368(2),148(4)]),xx(a)].
============================== end of proof ==========================
Yes, it's not easy for a human to read, but there's something final about having a computerised proof since it uses low-level logic (and there's also a "cool" factor).
- 21,079
Let $(M, \cdot, e)$ be a monoid. We have a morphism from $M$ to the monoid of $\mathcal{F}(M)$ of functions from $M$ to $M$, by $a \mapsto L_a$, where $L_a(b) = a \cdot b$. Clearly it maps invertible elements to invertible elements in $\mathcal{F}(M)$, that is, to bijective functions. Conversely, if $a\in M$ is such that $L_a$ is bijective, then $a$ is invertible in $M$. Indeed, since $L_a$ is surjective, there exists $b\in M$ such that $L_a(b) = e$, that is, $a b = e$. To show that $a$ is invertible, we need to check that $b a= e$, or, since $L_a$ injective, $a( b a) = a e$. By associativity the LHS equals $(a b) a = e a = a = a e$, and we are done.
If $M$ is the multiplicative monoid of an associative ring $R$, then:
$L_a$ is surjective if and only if $a b = e$ for some $b$ ( $a$ has a right inverse). Indeed, $a b = e$ implies $a b c = c$.
$L_a$ is injective if and only if $a$ is not a left zero divisor
- 53,909
