I can’t find an easy explanation for negative values of either/or sine, cosine and tangent when applied to angles outside $0-90^0$.
I tried to reason using the cosine law where is obvious that instead of cosine of an obtuse angle the negative cosine of the supplementary (acute) angle is used, but that is more of a redo of the cosine law than a reason for the negative value of the cosine of an obtuse angle.
I’ve tried to rely on unit circle to imagine $sine=\frac{vertical}{radius}$ while tracking a star. This led to $cosine=\frac{horizontal}{radius}$. I’m not into astronomy though. Then I looked at vertical measurement as positive when measured from ground up and negative when measured from ground under (when star falls under horizon). As for horizontal measurement, I took it negative ( as in “opposite direction”) after the observer needed to turn around to keep tracking a descending star. I did this in order to fit the unit circle.
This could explain the negative values the trigonometric functions take for angles outside $0-90^0$
Is there an easier explanation to why the trigonometric functions sometimes return negative values?
