I have a number theory question that has me stumped.
Let $a, b, c \in \Bbb Z$ with $a$ and $b$ both not zero. Prove: $(\frac{a}{(a,b)}, \frac{b}{(a,b)}) = 1$.
Any help would be greatly appreciated!
Pedro
  • 122,002
Neurax
  • 1,005
@vonbrand's comment is the most succinct answer. Here is a more verbose approach:
Let $d =\gcd(a,b)$. Let $l = \gcd(\frac{a}{d}, \frac{b}{d})$. Then $l \mid \frac{a}{d}$, $l \mid \frac{b}{d}$, which implies $ld \mid a$, $ld \mid b$. Hence $ld \le d$, from which we get $l \le 1$. Since $1 \mid a$, $1 \mid b$, we have $1 \le l$. So $l=1$.
copper.hat
  • 172,524
Bezout's identity will give you the answer immediately: http://en.wikipedia.org/wiki/B%C3%A9zout%27s_identity
It tells us that there exist integers $x,y$ such that $$xa+yb=(a,b).$$Divided by $(a,b)$ gives $x\frac{a}{(a,b)}+y\frac{b}{(a,b)}=1$, and note that the GCD of $\frac{a}{(a,b)}$ and $\frac{b}{(a,b)}$ must divide the RHS.
Easy
  • 4,485
$$ax+by=(a,b)$$ has a solution. Divide by $(a,b)$.
Thomas Andrews
  • 177,126
It is simply the special case $\: c = (a,b)\:$ of the $\,$ gcd distributive law $\ (a/c,b/c) = (a,b)/c$
See here for a few proofs of distributivity (by linearity (Bezout); universality; prime factorization).
Math Gems
  • 19,574
