Proof that the power of $2$ in $(3n)!$ is greater than or equals to the power of $2$ in $n!(n+1)!(n+2)!$.
I tried doing some algebraic manipulation,
$\frac{(3n)!}{n!(n+1)!(n+2)!}=\binom{(3n)!}{(n+2)!}\frac{(2n-2)!}{(n+1)!n!}=\binom{(3n)!}{(n+2)!}\binom{(2n-2)!}{(n+1)!}\frac{(n-3)!}{n!}=\binom{(3n)!}{(n+2)!}\binom{(2n-2)!}{(n+1)!}\frac{1}{(n-2)(n-1)n}$
Here, $\binom{(3n)!}{(n+2)!}$ and $\binom{(2n-2)!}{(n+1)!}$ are integers but $\frac{1}{(n-2)(n-1)n}$ is creating problems.
My argument is that some powers of $2$ from $\binom{(3n)!}{(n+2)!}$ and $\binom{(2n-2)!}{(n+1)!}$ would cancel out the powers of $2$ from $\frac{1}{(n-2)(n-1)n}$. But the argument is too ambiguous to be written down as a "proof".
Please let me know if there's a better way to approach these kinds of problems.
Any help would be highly appreciated.
Crocogator
  • 1,007
For $n=1$ it's wrong, but for $n=2$ it's true.
Let $$(3n)!\geq n!(n+1)!(n+2)!$$ for $n\geq2$.
Thus, $$(3n+3)!=(3n+1)(3n+2)(3n+3)(3n)!\geq$$ $$\geq(3n+1)(3n+2)(3n+3)n!(n+1)!(n+2)!\geq(n+1)!(n+2)!(n+3)!,$$ where the last inequality it's $$(3n+1)(3n+2)(3n+3)\geq(n+1)(n+2)(n+3),$$ which is obvious.
Now, use an induction, id est, the following reasoning.
Let $P(n)$ says $(3n)!\geq n!(n+1)!(n+2)!$ for any natural $n\geq2$.
We proved that:
  1. $P(2)$ is true;
  2. For any $n\geq2$ $P(n)\Rightarrow P(n+1)$ is true.
Thus, by the mathematical induction $P(n)$ is true for any $n\geq2$, which we needed to prove.
    @Toshu I added something. See now. – Michael Rozenberg Jan 05 '20 at 08:36
    Nothing in this argument considers the powers of $2$ in the numbers. In fact, we find that $6!=720=2^4\cdot45$ and $2!3!4!=2\cdot6\cdot24=288=2^5\cdot9$, so the claim is false for $n=2$. In general, let $a=2^m\cdot j$ and $b=2^n\cdot k$; proving $a\ge b$ does not prove $m\ge n$. The claim in the OP appears true for $n\ge 3$. – nickgard Jan 05 '20 at 10:02
  • @nickgard $720\geq288,$ which we need. It means $2^{720}\geq 2^{288}.$ – Michael Rozenberg Jan 05 '20 at 10:08
    @MichaelRozenberg Proving $(3n)!\ge n!(n+1)!(n+2)!$ for $n\ge 2$ is trivial. That's not what is being claimed. The claim is that if we write $(3n)!=2^x\cdot j$ and $n!(n+1)!(n+2)!=2^y\cdot k$, with $j,k$ odd, then $x\ge y$. – nickgard Jan 05 '20 at 10:56
    @nickgard Your problem for $n\geq3$ is interesting, but it is also trivial: we need to work with sums of numbers as $\left[\frac{3n}{2^i}\right]$. But why did you down-vote? – Michael Rozenberg Jan 05 '20 at 11:20
  • @nickgard I think so I've understood what happened. Apparently MichaelRozenberg assumed that the question meant $2^{(3n)!} ≥ 2^{n!(n+1)!(n+2)!}$. And I thought that if $(3n)!≥ n!(n+1)!(n+2)!$ then $\frac{(3n)!}{n!(n+1)!(n+2)!}=\binom{(3n)!}{(n+2)!}\binom{(2n-2)!}{(n+1)!}\frac{1}{(n-2)(n-1)n}>1$ so, the number $\binom{(3n)!}{(n+2)!}\binom{(2n-2)!}{(n+1)!}$ must be divisible by $(n-2)(n-1)n$ thus $(3n)!$ having greater power of $2$. This is incorrect because a number being greater than $1$ doesn't mean that it is an integer. – Crocogator Jan 05 '20 at 13:01
  • I realized it later. Correct me if I am wrong. – Crocogator Jan 05 '20 at 13:04
    @Toshu I think the only thing I can say is that my interpretation differs from Michael Rozenberg's interpretation. In an earlier comment I wrote: "The claim is that if we write $(3n)!=2^x\cdot j$ and $n!(n+1)!(n+2)!=2^y\cdot k$, with $j,k$ odd, then $x\ge y$." Was that a correct interpretation of your question? As to your approach, I think what you have said is correct, but I also think the given fraction is an integer for $n\ge 3$, so it may be a suitable approach if you can show that's true. – nickgard Jan 05 '20 at 13:45
    I politely request that you do not suggest I have made downvotes that I have, in fact, not made. I would very much like to see this question answered correctly. It is a question that is not as simple as it first seems. – nickgard Jan 05 '20 at 15:27
The claim is true for $n \ge 3$. As observed in the comments above it is false for $n = 1$ and $n = 2$.
We can apply Legendre's Formula in its alternate form for $p=2$:
$$\nu_2(n!)=n-s_2(n)$$
where $\nu_2(n)$ is the exponent of the largest power of $2$ that divides $n$ and $s_2(n)$ is the sum of the digits in the binary representation of $n$.
We will use the following facts for $a$ and $b$ positive integers:
  • $s_2(a+b) \le s_2(a) + s_2(b)$: it can be shown for example using Legendre's formula for $a+b \choose b$: $0 \le \nu_2({a+b \choose b}) = a+b-s_2(a+b)-b +s_2(b)-a+s_2(a)$;
  • $s_2(2a) = s_2(a)$;
  • $s_2(2a+1) = s_2(a)+1$;
  • $(eq. 1)$ $\nu_2((3n)!)-\nu_2(n!)-\nu_2((n+1)!)-\nu_2((n+2)!)=3n-s_2(3n)-n+s_2(n)-n-1+s_2(n+1)-n-2+s_2(n+2)=s_2(n)+s_2(n+1)+s_2(n+2)-3-s_2(3n)$
We divide the problem for $n$ even and odd:
1. $n = 2k+1$, $k \ge 1$
$$s_2(n)=s_2(2k+1)=s_2(k)+1$$ $$s_2(n+1)=s_2(2k+2)=s_2(2(k+1))=s_2(k+1)$$ $$s_2(n+2)=s_2(2k+3)=s_2(2(k+1)+1)=s_2(k+1)+1$$ $$s_2(3n)=s_2(6k+3)=s_2(2(3k+1)+1)=s_2(3k+1)+1=s_2(k+1+2k)+1 \le s_2(k+1)+s_2(2k)+1=s_2(k+1)+s_2(k)+1$$
and putting them together ($(eq. 1)$) it is enough to show that:
$$s_2(k)+2s_2(k+1)+2-3 \ge s_2(k+1) + s_2(k) + 1$$
i.e. $s_2(k+1) \ge 2$, which is true except for $k=2^m-1$, $m \ge 1$. In that case $n=2^{m+1}-1$ and:
$$s_2(n)=m+1$$ $$s_2(n+1)=1$$ $$s_2(n+2)=2$$ $$s_2(3n)=s_2(3 \cdot (2^{m+1}-1))=s_2(2^{m+2}+2^{m+1}-4+1)=s_2(2^{m+2}+4 \cdot (2^{m-1}-1)+ 1)= 1+m-1+1 = m+1$$
and combining them we need to show that:
$$m+4-3 \ge m+1$$
which is true.
2. $n = 2k$, $k \ge 2$
$$s_2(n)=s_2(2k)=s_2(k)$$ $$s_2(n+1)=s_2(2k+1)=s_2(2k)+1=s_2(k)+1$$ $$s_2(n+2)=s_2(2k+2)=s_2(2(k+1))=s_2(k+1)$$ $$s_2(3n)=s_2(6k)=s_2(3k)=s_2(2k+k) \le s_2(2k)+s_2(k) = 2 s_2(k)$$
$$2s_2(k)+1+s_2(k+1)-3 \ge 2s_2(k)$$
i.e. again $s_2(k+1) \ge 2$, which is true except for $k=2^m-1$, $m \ge 2$. In that case $n=2^{m+1}-2$ and:
$$s_2(n)=s_2(2^{m+1}-2)=s_2(2^m-1)=m$$ $$s_2(n+1)=s_2(2^{m+1}-1)=m+1$$ $$s_2(n+2)=s_2(2^{m+1})=1$$ $$s_2(3n)=s_2(3 \cdot (2^{m+1}-2))=s_2(3 \cdot (2^{m}-1))=s_2(2^{m+1}+2^{m}-4+1)=s_2(2^{m+1}+4 \cdot (2^{m-2}-1)+ 1)= 1+m-2+1 = m$$
$$2m+2-3 \ge m$$
i.e.
$$m \ge 1$$
which is true.
See also this linked question.
