I tried to find discriminant first and got two roots $$\frac{-1 + \sqrt{3}i}{2}$$ and $$\frac{-1 - \sqrt{3}i}{2}$$
I tried taking $x^2 = t$ and solving equation for root $w$ and $w^2$ but got stucked, and made it more complex, any help?
Sorry if I made any silly mistake, it's been while since I practiced complex equation and finding roots. Was helping my brother with his doubts :)
nonuser
  • 90,026
Iti Shree
  • 1,476
7 Answers7
Hint: Recall that $(a-b)(a^2+ab+b^2) = a^3-b^3$
Multiplying $$x^4 + x^2 + 1 = 0$$ with $x^2-1$ we get $$x^6-1=0$$ so $x^6=1$ and now is easy to finish...
nonuser
  • 90,026
$$x^4=-(x^2+1)\Rightarrow x^6=-x^4-x^2=x^2+1-x^2=1$$
So $$\sum x^6=\sum 1=1+1+1+1=4$$
Where $\displaystyle \sum x^6=\alpha^6+\beta^6+\gamma^6+\delta^6.$
jacky
  • 5,194
If you are going the hard way of finding explicitly the roots, then the roots and their exponential forms are $$\alpha=-\frac{1}{2}-\frac{i\sqrt{3}}{2}=-e^{\frac{i\pi}{3}} \Rightarrow\alpha^6=e^{i2\pi}=1$$ $$\beta=\frac{1}{2}+\frac{i\sqrt{3}}{2}=e^{\frac{i\pi}{3}}\Rightarrow\beta^6=e^{i2\pi}=1$$ $$\gamma=\frac{1}{2}-\frac{i\sqrt{3}}{2}=-e^{\frac{i2\pi}{3}}\Rightarrow\gamma^6=e^{i4\pi}=1$$ $$\delta=-\frac{1}{2}+\frac{i\sqrt{3}}{2}=e^{\frac{i2\pi}{3}}\Rightarrow\delta^6=e^{i4\pi}=1$$
rtybase
  • 16,907
$$(-1)^3=(x^4+x^2)^3=(x^3)^4+(x^3)^2+3(x^3)^2(-1)$$
Set $x^3=y$
$$y^4-2y^2+1=0$$ whose roots are $\alpha^3$ etc.
$$(y^4-2y^2+1)^2=0$$
Set $y^2=z$
$$z^4-4z^3+\cdots+1=0$$ whose roots are $(\alpha^3)^2$ etc.
Now apply Vieta's formula
Setting $t=x^2$, $t$ satisfies the quadratic equation $\;t^2+t+1=0$, and it is well known that the roots of this equation are the non-real cubic roots ot unity $$j=\mathrm e^{\tfrac{2i\pi}3}, \qquad \bar j=\mathrm e^{-\tfrac{2i\pi}3}.$$ Therefore the roots of the initial equation are the square roots of the previous roots, i.e. $$x\in\biggl\{\pm\mathrm e^{\tfrac{i\pi}3},\:\pm\mathrm e^{\tfrac{-i\pi}3}\biggr\},$$
and in each case, you can easily see that $x^6=1$.
Bernard
  • 175,478
$$ (x^2-1)(x^4+x^2+1) = x^6 - 1 $$ $x^6-1=0$ if and only if $x$ is one of the $6$th roots of $1.$
$(x^2-1)(x^4+x^2+1)=0$ if and only if either $x^2-1=0,$ in which case $x=\pm 1,$ or $x^4+x^2+1=0,$ which fails to hold if $x=\pm 1,$ since $(\pm 1)^4+(\pm 1)^2 + 1 = 3\ne0.$ Thus the roots of $x^4+x^2+1=0$ are the $6$th roots of $1$ other than $\pm 1.$ Their $6$th powers are equal to $1,$ so the sum of their $6$th powers is $4.$
  • Already written – nonuser Jan 01 '20 at 14:39
  • @Aqua : There are some students who will understand the answer in the way in which I wrote it and will not understand the way in which you wrote it. Think about the reason why that would happen. I see it frequently. – Michael Hardy Jan 01 '20 at 14:58
  • We do not need to consider whether or not $x^2 - 1$ is equal to zero though, we just need the implication $x^4 + x^2 + 1 = 0 \supset x^6 - 1 = 0$. – Maxim Jan 07 '20 at 20:33
An alternative approach. Your polynomial is $$ x^4+x^2+1 = (x^4+2x^2+1)-x^2 = (x^2+1)^2-x^2 = (x^2-x+1)(x^2+x+1) = \Phi_3(x)\Phi_6(x) $$ so for any root $\xi$ of the LHS, $\xi^6=1$. This implies $p_6=4$.
Jack D'Aurizio
  • 353,855
