Example of a finite commutative ring $R$ whose maximal ideal $I$ is not prime?
Is it possible? I am not able to find such example.
This is only possible if you ring lacks an identity.
Perhaps you didn't notice, but this is trivially derived from this solution, where $R=2\mathbb Z$ and $M=4\mathbb Z$ is given as an example, but obviously in the quotient $R/M$ has order $2$ and its zero ideal is maximal and nonprime.
Similarly this question can be adapted by saying $R=6\mathbb Z/12\mathbb Z$ has a maximal nonprime zero ideal (it is isomorphic to the ring above, as a matter of fact.)
And in fact this solution is exactly what you're asking for. So remember when you are reading duplicates, check their solutions too, because sometimes they do more than what the question asks of them.
No, it's not possible. For any commutative ring with $1$, any maximal ideal is prime.
Hint. use characterization of prime/maximal ideals in terms of quotient rings
