I was wondering if one can use Herbrand's Theorem to reduce completeness of first-order logic to completeness of propositional logic. I was thinking of the following argument:
If a formula does not have a model then by Herbrand's theorem the set consisting of all ground instances of the formula is propositionally unsatisfiable. So by the completeness of propositional logic there must be a propositional proof deriving a contradiction from a set of ground instances of the formula. But we can turn it into a derivation of a contradiction from our initial formula by just adding enough substitution steps at the top to generate the ground instances used.
Does this argument work?
    Can you write down the statement of Herbrand's theorem? It seems to me that the version of Herbrand's theorem that you're using only applies to universal first-order formulas. – Alex Kruckman Dec 26 '19 at 14:20
  • Sorry, I should have been clearer. I'am assuming that all existential quantifiers have been removed by Skolemization and the formula is implicitly universally quantified. Then the version of Herbrand's theorem I wish to use is: "If the formula has a model, then it has a Herbrand model." In rewriting the propositional proof, we can remove the Skolem functions if we wish by inserting proof steps invoking the elimination rule for the existential quantifier. – Jyotirmoy Bhattacharya Dec 27 '19 at 03:36
    I'm not sure I follow your argument precisely, but it seems potentially similar to Godel's original proof of the completeness theorem (see section 4 in Avigad's paper), although Herbrand isn't used there. – Noah Schweber Jan 02 '20 at 18:06
Let $\vdash_0$ denote the syntactic consequence relation of classical propositional logic, and $\vdash$ the same for classical first-order logic.
Let $\Gamma$ range over sets of first-order sentences. You wish to prove the following. "if $\Gamma$ does not have a model, then you can use classical first-order logic to derive a contradiction from $\Gamma$ (symbolically, $\Gamma \vdash \bot$)". Here's how I read the argument you sketch:
  1. Assume $\Gamma$ does not have a model.
  2. We put all sentences of $\Gamma$ in prenex form, and extend the language with enough function symbols so that we can Skolemize/Herbrandize. Call the result $\Gamma_h$. Then $\Gamma_h$ still does not have a model.
  3. Applying Herbrand's theorem to 2, we get some finite subset $F$ of the ground instances of $\Gamma_h$ that does not admit a propositional valuation.
  4. Applying completeness for propositional logic to 3, we get that classical propositional logic derives a contradiction from $F$, or symbolically $F \vdash_{0} \bot$.
  5. Since we have $F \vdash_{0} \bot$, we clearly also have $F \vdash \bot$.
  6. But we have $\Gamma_h \vdash f$ for each $f \in F$, and therefore we must have $\Gamma_h \vdash \bot$.
  7. Since $\Gamma_h \vdash \bot$, we also have $\Gamma \vdash \bot$.
Is this argument correct? First, let's look at things that could potentially go wrong, but don't.
  • Steps 5 and 6 are obvious, but if you want to make assurance double sure, you can prove the relevant results by induction on the structure of classical propositional logic proofs.
  • Does step 4 work? Sure, the completeness theorem for classical propositional logic says exactly this.
  • Do steps 2 and 7 work, and are they circular? I suppose you might be worried about this part. Short answer: yes, they work, and without circularity. You can show step 2 using purely semantic arguments, and step 7 using purely syntactic considerations (e.g. by inspecting sequent calculus proofs).
At this point you should feel reassured that your argument is by-and-large correct, modulo some details, such as a precise treatment of equality in the propositional case. (in fact, I'm fairly sure I've seen this exact argument in the literature, will try to find a reference later)
But there's one additional matter. Based on your comments, the "Herbrand's theorem" you wanted to use was the following: "if a set of sentences has a model, then its set of ground instances admits a propositional valuation". This is half of Herbrand's actual theorem, and in some sense it's the trivial half. For let $\mathcal{M}$ be the said model: then the desired valuation can be obtained by setting a ground instance $\varphi$ true precisely if $M \models \varphi$.
This half simply won't do. To go from step 2 to step 3, you need to use the other direction of Herbrand's theorem, "if a set of sentences does not have a model, then its set of ground instances does not admit a propositional valuation". The way we normally prove this should remind you of standard proofs (e.g. Henkin's) of the model existence theorem.
We will prove the contrapositive, i.e. if the set $\mathcal{F}$ of ground instances of $\Gamma_h$ admits a propositional valuation $v$, then $\Gamma_h$ has a model. Consider the set $T$ of all terms in the (extended) language. Interpret each function symbol $\mathtt{f}$ of arity $n$ as the set $f=\{ (x_1,\dots,x_n,y) \in T^{n+1} \:|\: y = \mathtt{f}(x_1,\dots,x_n) \}$. Interpret each relation symbol $\mathtt{R}$ of arity $n$ as the set $R = \{ (x_1,\dots,x_n) \in T^n \:|\: v(\mathtt{R}(x_1,\dots,x_n)) = \text{true} \}$. Call the resulting structure $\mathcal{M}$: since $\Gamma_h$ has no existential quantifiers, $\mathcal{M} \models \varphi$ precisely if $v(\varphi') = \text{true}$ for any ground instance $\varphi'$ of $\varphi \in \Gamma_h$, as can be verified by a simple induction on the structure of $\varphi$. Note that instead of $\mathcal{F}$, we could have started with all finite subsets of $\mathcal{F}$: if each of these admits a propositional valuation, then by propositional compactness so does the entire set $\mathcal{F}$. I'd say this is the core of the argument: when the idea of constructing a model from the ground terms forms the core of all standard proofs of completeness, taking a detour via Herbrand might even start feeling like cruft.
Z. A. K.
  • 11,359
