My teacher has given us a rather long problem and the last part is stumping me. How would one go about factoring the power series of sin(x)? Where:
p(x) = x - $\frac{x^{3}}{3!}$ + $\frac{x^{5}}{5!}$ - $\frac{x^{7}}{7!}$ ...
Better expressed as:
p(x) = $\sum_1^\infty (-1)^{n+1} * \frac{x^{2n-1}}{(2n-1)!}$
The exact phrasing of the last question is:
Use the roots to give an infinite factorization of p(x).
Where in a previous step of the problem, I have already figured out the roots to be -$\pi$, 0, and $\pi$.
LucasS
  • 175
When you [completely] factor a normal (finite) polynomial $p(x)$, you get an expression that looks like $$ p(x) = c\prod_{i = 1}^n(x - a_i) $$ for some $a_i$ and $c$ in your field (here it would be $\Bbb{C}$ or $\Bbb{R}$). For a normal polynomial, this product is always finite because the number of roots of your polynomial is always less than or equal to the degree of the polynomial (equal if you're working in an algebraically closed field); however, $\sin x$ isn't a polynomial (or at least a finite polynomial), and it has infinitely many roots: $\sin k\pi = 0$ for all $k\in\Bbb{Z}$. However, this gives us an idea of a "factorization" for $\sin x$ as a product of its roots: $$ \sin x "=" c \prod_{k\in\Bbb{Z}} (x - k\pi), $$ where the $c$ is some constant to be determined. You might guess that this constant is just going to be $1$, because you know $$ \sin x = x - \frac{x^3}{3!} + \frac{x^5}{5!} + \ldots, $$ and if you start to "multiply" out the terms in the product, you'll wind up with $cx$ as the first term. In fact, $c = 1$ turns out to be the right choice. So we have $$ \sin x "=" \prod_{k\in\Bbb{Z}} (x - k\pi). $$
If we're clever, we can also see that the polynomial $1 - \frac{x^2}{k^2\pi^2}$ is $0$ when $x = \pm k\pi$, and the product of such things along with another $x$ seems to give the proper terms for the $\sin x$ power series, so we might actually have $$ \sin x "=" x\prod_{k = 1}^{\infty}\left(1 - \frac{x^2}{k^2\pi^2}\right), $$ which turns out to be the case (although a lot more analysis is required to rigorously prove that this formula is true).
Stahl
  • 23,212
I show here the method used by Euler.
  • Initial Identities:
Euler showed that
\begin{eqnarray} \frac{\sin z}{z} = \prod_{k=1}^{\infty} \left ( 1 - \frac{z}{k^2 \, \pi^2} \right ) \end{eqnarray} He started by considering his formula \begin{eqnarray} e^z = \lim_{n \to \infty} \left ( 1 + \frac{z}{n} \right )^n, \end{eqnarray} and the substitution of $z$ by $\mathrm{i} z$, so \begin{eqnarray} e^{\mathrm{i} z} = \lim_{n \to \infty} \left ( 1 + \frac{\mathrm{i} z}{n} \right )^n \end{eqnarray} Then from using this in the identity, \begin{eqnarray} \sin z = \frac{e^{i z} - e^{-i z}}{2 \mathrm{i}} \end{eqnarray} he found \begin{eqnarray} \sin z = \lim_{n \to \infty} \frac{ \left ( 1 + \frac{iz}{n} \right )^n - \left ( 1 - \frac{i z}{n} \right )^n }{2 \mathrm{i}}. \end{eqnarray} The key idea of Euler here was the factorization of this binomial as presented in the next section.
  • Factorization using roots of unity
Assume $n= 2 p + 1$. The roots of the equation \begin{eqnarray} T^n -1 = 0 \end{eqnarray} are \begin{eqnarray} T_r = e^{\frac{2 \pi r \mathrm{i}}{n}}, \quad (r=0, \pm 1, \pm2, \cdots \pm p ). \end{eqnarray} One of the roots is $T_0=1$, while the other roots come in conjugate pairs, leading to the second degree polynomial \begin{eqnarray} (T - e^{\frac{2 \, \pi \mathrm{i}}{n}}) (T - e^{-\frac{2 \, \pi \mathrm{i}}{n}} ) = T^2 - 2 \, T \cos \left ( \frac{2 r \pi}{n} \right ) + 1 \quad r=1,2, \cdots p, \end{eqnarray} so the polynomial $T^n -1$ can be factored out as \begin{eqnarray} T^n -1 = (T-1) \prod_{k=1}^{p} \left [ T^2 - 2 T \cos \left ( \frac{2 k \pi}{n} \right ) + 1 \right ] \quad (1) . \end{eqnarray} Next we make the substitution $T=X/Y$ and clear fractions to get \begin{eqnarray} X^n - Y^n = (X-Y) \prod_{k=1}^{p} \left [ X^2 - 2 X Y \cos \left ( \frac{2 \, k \pi}{n} \right ) + Y^2 \right ] \end{eqnarray} We now we do one more substitution. This is \begin{eqnarray} X = 1 + \frac{iz}{n}, \quad \quad Y = 1 - \frac{iz}{n} \end{eqnarray} and after defining \begin{eqnarray} q_n(z) = \frac{ \left ( 1 + \frac{iz}{n} \right )^n - \left ( 1 - \frac{i z}{n} \right )^n }{2 \mathrm{i} z}. \end{eqnarray} and using $X-Y= 2 \mathrm{i} z/n$, we find
\begin{eqnarray} \label{qnz} q_n(z) &=& \frac{1}{n} \prod_{k=1}^{p} \left [ \left ( 1 + \frac{iz}{n} \right )^2 - 2 \left ( 1 + \frac{iz}{n} \right ) \left ( 1 - \frac{iz}{n} \right ) \cos \left ( \frac{2 k \pi}{n} \right ) + \left ( 1 - \frac{iz}{n} \right )^2 \right ] \nonumber \\ &=& \frac{1}{n} \prod_{k=1}^{p} \left ( 2 - \frac{2 z^2}{n^2} - 2 \left ( 1 + \frac{z^2}{n^2} \right ) \cos \frac{2 k \pi}{n} \right ) \nonumber \\ &=& \frac{1}{n} \prod_{k=1}^{p} 2 \left ( 1 - \frac{ z^2}{n^2} - \left ( 1 + \frac{z^2}{n^2} \right ) \cos \frac{2 k \pi}{n} \right ) \nonumber \\ &=& \frac{1}{n} \prod_{k=1}^{p} 2 \left [ \left ( 1 - \cos \frac{2 k \pi}{n} \right ) - \frac{z^2}{n^2} \left ( 1 + \cos \frac{2 k \pi}{n} \right ) \right ] \nonumber \\ &=& \frac{1}{n} \prod_{k=1}^{p} 2 \left ( 1 - \cos \frac{2 k \pi}{n} \right ) \left [ 1 - \frac{z^2}{n^2} \frac{ 1 + \cos \frac{2 k \pi}{n}} {1 - \cos \frac{2 k \pi}{n}} \right ] \quad (2) \end{eqnarray}
Now, from equation (1) we see that \begin{eqnarray} \frac{T^n -1}{T-1} = \prod_{k=1}^{p} \left [ T^2 - 2 T \cos \left ( \frac{2 k \pi}{n} \right ) + 1 \right ]. \end{eqnarray} On the other hand we know the trivial identity \begin{eqnarray} \frac{T^n -1}{T-1} = 1 + T + T^2 + \cdots + T^{n-1} \end{eqnarray} Therefore \begin{eqnarray} \lim_{T \to 1}\frac{T^n -1}{T-1} = \prod_{k=1}^{p} \left [ 2 - 2 \cos \left ( \frac{2 k \pi}{n} \right ) \right ] = n \end{eqnarray} so equation~\ref{qnz} simplifies to \begin{eqnarray} q_n(z) &=& \prod_{k=1}^{p} \left ( 1 - \frac{z^2}{n^2} \; \frac{ 1 + \cos \frac{2 k \pi}{n}} {1 - \cos \frac{2 k \pi}{n^2}} \right ) \quad (3) . \end{eqnarray}
We know that \begin{eqnarray} \lim_{n \to \infty} q_n(z) = \frac{\sin z}{z}. \end{eqnarray} We now should find the limit as $n \to \infty$ in equation (3).
Euler assumed that the limit could go inside the product sign. We have the following calculus identities (easily derived from Taylor expansion of the cosine function) \begin{eqnarray} \label{identu0} \lim_{u \to 0} \frac{1 - \cos a u}{a^2 u^2} &=& \frac{1}{2} \nonumber \\ \lim_{u \to 0} \left ( 1 + \cos a \, u \right ) &=& 2 . \end{eqnarray} By choosing $a= 2 k \pi$ and $u=1/n$ in the first identity above we find \begin{eqnarray} \lim_{n \to \infty} n^2 \, \left ( 1 - \cos \frac{2 k \pi}{n} \right ) &=& 2 k^2 \pi^2. \end{eqnarray} so \begin{eqnarray} \label{qnz3} \lim_{n \to \infty }q_n(z) = \prod_{k=1}^{p} \left ( 1 - \frac{2 z^2}{2 k^2 \pi^2} \right ) = \prod_{k=1}^{p} \left ( 1 - \frac{z^2}{k^2 \pi^2} \right ). \end{eqnarray}
Therefore \begin{eqnarray} \frac{\sin z}{z} = \prod_{k=1}^{\infty} \left ( 1 - \frac{z^2}{k^2 \pi^2} \right ) \quad (4). \end{eqnarray}
  • Discussion
The materialization of this idea took Euler him more than 10 years of work. Euler thought about the infinite series as extensions of polynomials where the roots can be used to factorize them. If this is true, then it is natural to think that \begin{eqnarray} \sin z = z \left ( 1- \frac{z}{\pi} \right ) \left ( 1 - \frac{z}{2 \pi} \right ) \cdots \left ( 1-\frac{z}{k \pi} \right ) \cdots \nonumber \\ \left ( 1- \frac{z}{-\pi} \right ) \left ( 1 - \frac{z}{-2 \pi} \right ) \cdots \left ( 1-\frac{z}{-k \pi} \right ) \cdots \end{eqnarray} where $\sin z$ vanishes at each $z= \pm k \, \pi$, $k=0,1, \cdots $. Then by grouping each factor with that where its root has the opposite sign, he found \begin{eqnarray} \sin z = z \left ( 1- \frac{z^2}{\pi^2} \right ) \left ( 1 - \frac{z^2}{2^2 \pi^2} \right ) \cdots \left ( 1-\frac{z^2}{k^2 \pi^2} \right ) \cdots \nonumber \\ \end{eqnarray} which coincides with (4). However he got many objections. For example
  • How does he knows that the order of the factorization does not matter in the infinite.
  • Are those the only complex roots of $\sin z$?,
  • $\sin s/s$ and $e^s \sin s/s$ have the same roots, but clearly can not be factored with the same formula.
Euler was encouraged by the fact that his formula checked out fine for some particular values found before by Newton and Leibniz's. Also he evaluated the Zeta function $\zeta(2)=\pi^2/6$ and matched with good accuracy.
The point of convergence is not addressed here. Is there a radius of convergence (as in infinite series)?
In the proof presented here, still we can not guarantee that the limit can be interchanged with the $\prod$ sign. That is, is the limit of the product equal to the product of the limits? That this could be done was proved at a much later time by Weierstrass who generalized Euler's result with his theorem, that entire functions can be represented by a product involving their zeroes and in addition, every sequence tending to infinity has an associated entire functions with zeroes at precisely the points of that sequence (see Wikerstrass factorization theorem'').
Reference: https://books.google.com/books?id=CYyKTREGYd0C
