A monic degree-5 polynomial in $\mathbb{Z}_{5}[x]$ for which all elements of $\mathbb{Z}_{5}$ are roots I found is $(x^5 - x)$ since
$f(1) \equiv$ 0(mod 5) $f(2) \equiv$ 0(mod 5) $f(3) \equiv$ 0(mod 5) $f(4) \equiv$ 0(mod 5) $f(5) \equiv$ 0(mod 5).
I am wondering, however, if there could be more than one answer. I noticed that $(x^5 - x)$ is a difference and can be factored but I don't know if that is a good conjecture.
yagayeet
  • 373
  • $(x)(x-1)(x+1)(x-2)(x+2)=x(x^2-1)(x^2-4)\equiv x(x^2-1)(x^2+1)=x(x^4-1)=x^5-x$ – J. W. Tanner Dec 03 '19 at 23:14
  • @J.W.Tanner I agree, but isn't this the same solution as $(x^5 - x)$? – yagayeet Dec 03 '19 at 23:14
    yes, I think it's the only solution, because any solution has to be a multiple of $x(x-1)(x-2)(x-3)(x-4)(x-5)\equiv x^5-x$, and there's only one monic $5^{th}$ degree polynomial that fits that bill – J. W. Tanner Dec 03 '19 at 23:15
Hint: if their were two then their difference is a nonzero polynomial of degree $< 5$ with $5$ roots, contra: a polynomial in a field (or domain) has no more roots than its degree.
Remark $ $ More generally, by above if $f(x) = 0\,$ for all $x$ then $\deg f \ge 5.\,$ Let $\, g = x^5-x.\,$ Note $h = f\bmod g = f - q\,g\,$ also has $\,h(x) = 0$ for all $x$ and $\,\deg h < 5\,$ so $\, h = 0,\, $ so $\,f = q\,g.\,$ Thus any other polynomial having the same set of roots is a multiple of the minimal degree polynomial $g$.
Remark $ $ This is a special case of the fact that ideals in Euclidean domains are principal - generated by any element of minimal Euclidean value(= degree here).
Bill Dubuque
  • 272,048
