I'm trying to calculate the following sum: $C_n = \sum_{k=0}^{n} \cos\left(\dfrac{2k\pi}{2n+1}\right)$
In order to get hints, I programmed the following code in Python:
from math import *
def C(k,n):
return cos((2*k*pi)/(2*n+1))
S = 0.0
n = int(input("choose a value for n: "))
while(True):
for k in range(n+1):
S += C(k,n)
print('step ', k,' is S = ',S)
S = 0.0
print('\n\n')
The sums all end up equal to 0.5. Wolfram Alpha agrees.
I..don't.. I tried to express the cosine as $\dfrac{e^{i\frac{2k\pi}{2n+1}}+e^{-i\frac{2k\pi}{2n+1}}}{2}$, then extract the $k$ as a power like so: $\sum_{k=0}^{n}\dfrac{ \left( e^{i\frac{2\pi}{2n+1} }\right)^k+ \left(e^{-i\frac{2\pi}{2n+1}} \right)^k }{2}$
$= \dfrac{1}{2} \sum_{k=0}^{n} \left(e^{i\frac{2\pi}{2n+1}}\right)^k +\left(e^{-i\frac{2\pi}{2n+1}} \right)^k$
That way, if I'm correct, those two terms are each a sum of terms of a geometric series. While a $\dfrac{1}{2}$ does appear later on as separate term, this approach seems to create more problems than it solves.
I would be grateful for any pointers :) Thanks in advance.
