How do I prove that the equation $x^4 - y^4 = 2 z^2$ has no solutions using the fact that the equations $x^4 + y^4 = z^2$ and $x^4 - y^4 = z^2$ have no solutions. I cant think of a method of reducing the above equation to one of these forms.
Are $x,y,z$ integers? – Jemmy Mar 22 '13 at 18:55
Can you substitute $z = \frac{z'}{\sqrt{2}}$ for $z$ in the first equation? Then you have an equation of the form $x^4+y^4=z^2$. Apologies if this is in error - I can't remember if this is valid. – SSumner Mar 22 '13 at 18:55
apparently $x,y,z$ are integers. – Mar 22 '13 at 18:56
1I assume $x$ and $y$ must be distinct, or you have a solution. – ncmathsadist Mar 22 '13 at 19:00
yah x,y,z are integers – noddy Mar 22 '13 at 19:01
yes they are district also – noddy Mar 22 '13 at 19:01
Also, $x^4+y^4=z^2$ has solutions when $y=0$ for instance, $(1,0,1)$. – Baby Dragon Mar 22 '13 at 19:21
You may not ave to reduce it to the above forms if you know http://math.stackexchange.com/questions/150885/proving-that-mathbbz-sqrt2-is-a-euclidean-domain . But I am sure if this is appropriate to your backround. – Baby Dragon Mar 22 '13 at 19:35
I think you meant nonexistence of positive solutions. Suppose that there exist some positive solutions(meaning that all of $x$, $y$, $z$ are positive). Then there is a positive solution $(x_0,y_0,z_0)$ with $x_0$ smallest.
First, notice that parity of $x_0$ and $y_0$ cannot be different. So, either both even or both odd. Both even case is not possible, because otherwise $(x_0/2,y_0/2,z_0/4)$ is a positive solution solution with smaller $x_0$.
Similarly with odd prime $p$, suppose $p|gcd(x_0,y_0)$, then you also get smaller solution $(x_0/p, y_0/p, z_0/p^2)$. Thus we can assume $(x_0,y_0)=1$.
Thus we can now assume that $x_0$ and $y_0$ are both odd, and coprime. Then by looking at the expression $$ \frac{x_0^2-y_0^2}{2}\cdot \frac{x_0^2+y_0^2}{2}=\frac{z_0^2}{2} $$
The right side must be an integer, so it must be $2Z^2$ , and any prime $p$ cannot divide both $\frac{x_0^2-y_0^2}{2}$ and $\frac{x_0^2+y_0^2}{2}$(otherwise we would have some prime $p$ dividing both $x_0$ and $y_0$. Then we have $$ x_0^2-y_0^2 = u^2$$ , and $$x_0^2+y_0^2 = 2v^2$$ for some positive integers $u,v$.
Now we solve for the Pythagorian triple in the first equation. $$ x_0=s^2+t^2\\ y_0=s^2-t^2\\ u=2st $$ for some positive integers $s,t$.
Then $x_0^2+y_0^2=2(s^4+t^4)=2v^2$. Hence we obtain $s^4+t^4=v^2$. However, this cannot have positive integer solution.
- 20,102
Why do we have $x_0^2-y_0^2 = u^2$? Couldn't we have $x_0^2-y_0^2 = 2u^2$ instead? – Mar 23 '13 at 03:47
We started from both $x_0$ and $y_0$ odd. So for all prime power divisor of $(x_0^2+y_0^2)/2$ is odd, and the powers are even in $2Z^2$. – Sungjin Kim Mar 23 '13 at 04:53
Oh I see. Using modulo 4, we see that $(x_0^2+y_0^2)/2$ is the odd factor, and $(x_0^2-y_0^2)/2$ is the even one. – Mar 23 '13 at 14:41
IDENTITY--The identity $(X^4 - Y^4)^2 + 4(XY)^4 = (X^4 + Y^4)^2 $ solves the proposer's question.
The proposer assumes that there is a non-zero triple of integers X,Y,Z
such that $(X^4 - Y^4 ) = 2(Z^2)$. WOLOG we may assume $(X,Y,Z) =1$.
We substitute " $2(Z^2)$ " for $(X^4 -Y^4)$ in the above IDENTITY.
This translates to $(2Z^2)^2 + 4(XY)^4 = (2B)^2$ where $X^4 + Y^4 = 2B$. ( Note that X,Y, are both odd as $X^4 = Y^4 = 2(Z^2)$ by hypothesis. Hence we may write $X^4 + Y^4) = 2B$ for some nonzero integer $B$ in the above IDENTITY.)
Dividing both sides by $4$ yields
$Z^4 + (XY)^4 = B^2$, which Fermat proved is impossible in non-zero integers $Z$,$(XY)$, and $B$ and is the connection that the proposer was seeking.
Many thanks to JW Tanner and Tinlyx for improving the formatting of this proof. I wanted to share the above IDENTITY equation with the readership because it is an important tool to shorten and simplify Fermat-type equations of exponent $4$ which may or may not have a "$2$" as a coefficient. The first answer given to this problem above is correct, but this solution is also very elegant, and simpler as well.
- 880
- 23
1As it’s currently written, your answer is unclear. Please [edit] to add additional details that will help others understand how this addresses the question asked. You can find more information on how to write good answers in the help center. – Community Jan 06 '23 at 04:49
