I am working on this question:
Given $2$ metric spaces $(X, d_{X})$ and $(Y, d_{Y})$ with some bound $M$ of $d_{X}+d_{Y}$ and $X\cap Y=\varnothing.$ Then, we can define a metric on $X\cup Y$, by $$d(u,v)=d_{X}(u,v)\ \text{if}\ u,v\in X,$$ $$d(u,v)=d_{Y}(u,v)\ \text{if}\ u,v\in Y,$$ $$d(u,v)=M\ \text{if}\ u\in X,\ v\in Y.$$ Check that this satisfies the axioms to show that $d(u,v)$ induces a metric on $X\cup Y$.
A similar question was asked here: Disjoint Union of Metric Spaces is a Metric Space, but this post was about the proof of triangle inequality and this post specified the upper bound $M=1$.
I have two other questions:
(1) How to show $d(u,v)=d(v,u)$? This equality holds immediately for $u,v\in X$ or $u,v\in Y$, but the case of $u\in X$ and $v\in Y$ is a little bit confusing. If we have chosen $u\in X$ and $v\in Y$, $d(u,v)=M$ is true by definition, but is it true that the $d(v,u)$ is not defined? (since the definition specifies that the first coordinate is in $X$ and the second is in $Y$).
(2) Can $M=0$? At first I thought $M$ cannot be $0$, but I could not prove it.
If $M=0$, then for all $x_{1}, x_{2}\in X$ and $y_{1}, y_{2}\in Y$, we have $$d_{X}(x_{1}, x_{2})+d_{Y}(y_{1}, y_{2})\leq 0,$$ implies $$d_{X}(x_{1}, x_{2})\leq -d_{Y}(y_{1}, y_{2}),$$ but both of them are nonnegative, and thus for all $x_{1}, x_{2}\in X$ and $y_{1}, y_{2}\in Y$, $$d_{X}(x_{1}, x_{2})=d_{Y}(y_{1}, y_{2})=0,$$ which happens if and only if $x_{1}=x_{2}$ and $y_{1}=y_{2}.$
This implies that $X$ and $Y$ are just two distinguished points. Then if you choose $x\in X$, and $y\in Y$, then by definition $d(x,y)=M=0$.
Then I want to use $d(x,y)=0$ as a contradiction since $X\cap Y=\varnothing$. However, given the post here:
Find two closed subsets or real numbers such that $d(A,B)=0$ but $A\cap B=\varnothing$
and here:
Prove that if $A$ is compact and $B$ is closed and $A\cap B = \emptyset$ then $\text{dist}(A,B) > 0$
I don't think it gives me any contradiction.
