I am confused about several things about open and closed mapping in relations to the listed and question below. I came across them in two different general topology texts. Thank you in advance.
1) Verify that a mapping $f$ of $X$ to $Y$ is closed if and only if $\overline{f(A)}=f(\overline{A})$ for every $A\subset X$ and that $f$ is an open mapping if and only if $f$ is continuous and $f(\mathring{A})\subset \mathring{f(A)}$ [$f(Int A) \subset Int f(A)$]
Here, am I to interpret to mean:
A mapping $f$ of $X$ to $Y$ is closed if and only if $\overline{f(A)}=f(\overline{A})$ for every $A\subset X$
if and only if
or are the two separate statements?
Theorem 1 (according to Engelking's General Topology Revised and completed edition): For a one-to-one mapping $f$ of a topological space $X$ onto a topological space $Y$ the following conditions are equivalent:
(i) the mapping $f$ is a homeomorphism.
(ii) The mapping $f$ is closed.
(iii) The mapping $f$ is open.
(iv) The set $f(A)$ is closed in $Y$ if and only if $A$ is closed in $X$
(iv') The set $f^{-1}(B)$ is closed in $X$ if and only if $B$ is closed in $Y$
(v) The set $f(A)$ is open in $Y$ if and only if $A$ is open in $X$.
(v') The set $f^{-1}(B)$ is open in X if and only if $B$ is open in $Y$.
For theorem 1 above, for a function to be open and hence continuous between topological spaces, all it need from the function is that it being one to one.
Theorem 2 (for one direction stated in Dugundji's Topology Text, I changed the notation from $p$ to $f$ for function, otherwise everything else is as worded in the text)
(2b-1) Let $f:X\rightarrow Y$ be a closed map. Given any subset $S \subset Y$ and any open $U$ containing $f^{-1}(S)$, there exists an open $V \supset S$ such that $f^{-1}(V) \subset U$
(2b-2) Let $f:X\rightarrow Y$ be a closed map. Given any subset $S \subset Y$ and any open $A$ containing $f^{-1}(S)$, there exists an open $B \supset S$ such that $f^{-1}(B) \subset A$
Theorem 3 (according to Engelking's General Topology Revised and completed edition) A continuous mapping $f:X\rightarrow Y$ is closed (open) if and only if for every $B\subset Y$ and every open (closed) set $A\subset Y$ which contains $f^{-1}(B),$ there exists an open (a closed set $C\subset Y$ containing $B$ such that $f^{-1}(C)\subset A$
For theorems 2 and 3 above, in one direction for theorem 2 (2b-1 and 2b-2), I don't need to assume anything about the function other than it is open. But if I want to show the converse, which is theorem 3 above, I do need the function to be continuous? What about given theorem 1, can't I just change the function to be just one to one, then i would get the converse?
Seth
  • 3,325
  • An open map needn't be continuous: https://math.stackexchange.com/a/75601/403337 –  Sep 12 '19 at 03:04
  • @ChrisCuster that I know. But here the theorem from the particular text i referenced, it seems that all one need is a much more simpler criteria, then one get everything they want. It seems like a bargain. – Seth Sep 12 '19 at 03:06
  • @SujitBhattacharyya thank you for telling me that. – Seth Sep 12 '19 at 03:07
  • A “mapping” often is a term for “continuous function” and that’s the case in your first theorems. So continuity is assumed throughout. – Henno Brandsma Sep 12 '19 at 08:38
  • @HennoBrandsma do you mean when i see a theorem or question about open/closed functions and I see the word "mapping" along with it. I can assume that the function is continuous. But if I don't "mapping" present, and just prove such and such function is either open/closed function or a function's properties, then i can't assume anything about the function. Am I correct? – Seth Sep 12 '19 at 08:48
  • @SujitBhattacharyya false. An onto map can be continuous and open and not closed. – Henno Brandsma Sep 12 '19 at 08:50
  • @SethMai I mean that you have to look at the whole text and not just cherrypick a statement from it without looking at all definitions involved. – Henno Brandsma Sep 12 '19 at 08:52
  • @HennoBrandsma, I look through Engelking's text. He only uses mapping to talk about the definition of a function. That is why these theorems seem to be confusing. It seems like some of them only have continuity as requirement,another one assumes function only being injective. In many instances, the common statement is that if a function is open, then nothing else can be inferred. Here, these theorems are saying if we assume much less, then we can infer even more. So which is which. – Seth Sep 12 '19 at 08:57
  • @SethMai the full Engelking statement is true for a continuous $f$ that is also 1-1. Open and closed are equivalent for 1-1 functions in general, but we lose the equivalence with homeomorphism when the function is not continuous. – Henno Brandsma Sep 12 '19 at 09:01
  • @HennoBrandsma does that mean if f is either an open nor closed function, then f is also one to one only. But if the function is not continuous, then an open/closed function and being one to one is not equivalent to being homeomorphic. Is that what you meant? – Seth Sep 12 '19 at 09:06
  • @SethMai no, I mean that if you know a function is 1-1 and it’s open then it’s closed too, and vice versa. But a function can be open and closed and not 1-1 too. Etc. – Henno Brandsma Sep 12 '19 at 09:15
  • @HennoBrandsma but as far the theorem 1 I reference from Engelking in my post. The function f is implicity assume to be continuous. The way is phrased with all the equivalence, the wording looks like given a one to one function, we can show that the function is homeorphic, which implies it is open, then, closed, etc, etc all the way back to showing that it is homeorphic. My apologizes if i am belabouring this. – Seth Sep 12 '19 at 09:22
  • @HennoBrandsma or am I to interpret the theorem to be saying, if I am given a one to one function, and the function is also homeomorphic, which is (i), then it is equivalent to (ii), (iii), etc, etc – Seth Sep 12 '19 at 09:24
  • @SethMai you’re given a 1-1 continuous function. If you know one of the subsequent facts you know all the others too. – Henno Brandsma Sep 12 '19 at 09:39
  • the two statements are separate, 2. some authors, I believe including Engelking, reserve the term "mapping" or "map" for continuous functions. That is, a function need not be continuous, but if you honor it by calling it a mapping, then it must be continuous. (Perhaps such a convention is made early in the book, and holds throughout without further mentioning.)
  • – Mirko Sep 12 '19 at 14:33
  • @Mirko Engelking on pg. 1 states: The relation $f \subset X \times Y$ is called a function from $X$ to $Y$, or a mapping of $X$ to $Y$, if every $x \in X$ there exists a $y \in Y$ such that... – Seth Sep 12 '19 at 16:53
  • @SethMai page 31 bottom makes clear that an open mapping is in particular a continuous one. – Henno Brandsma Sep 12 '19 at 21:41
