How to evaluate the following integral
$$\displaystyle \int_0^\infty \frac{\sin{(\omega\tau)}\sin{(\omega y)}\sinh\,(\omega x)}{\sinh{(\omega a)}} \,\text{d}\omega$$
where $a > 0$, $x \in (0,\, a)$ , $y \in (0,\,\infty)$ and $\tau \in (0,\,\infty)$? The solution should be a function of $x\,,y\,,\tau\,,a$.
Any clues? I heard that it has a closed form and can be expressed by elementary functions. Any idea will help! Thanks.
Is it equivalent to $\frac{\sin{(\dfrac{\pi}{a} x)}\sinh\,(\dfrac{\pi}{a}y)\sinh(\dfrac{\pi}{a} \tau)}{\sin^2(\dfrac{\pi}{a} x)\sinh^2(\dfrac{\pi}{a} y) \,+\, [\cos\,(\dfrac{\pi}{a} \tau)\,+\,\cos\,(\dfrac{\pi}{a} x)\cosh\,(\dfrac{\pi}{a} y)]^2}$ ?
    Try integrate by parts. Let $u=\sin(\omega \tau)\sin(\omega y)$ and to let $dv=\frac{\sinh(\omega x)}{\sinh(\omega y)}d\omega$. Use $\sin(b)=\frac{e^b-e^{-b}}{2i}$ and use $\sinh(b)=\frac{e^b-e^{-b}}{2}$ when necessary. – Hussain-Alqatari Sep 11 '19 at 08:49
    @Hussain-Alqatari: Did you try it yourself? (Specifically, what is $v$?) – metamorphy Sep 11 '19 at 10:41
  • I'm wondering whether this can't be done if all the involved functions are reduced to their exponential forms. – Allawonder Sep 11 '19 at 12:53
The integral $$f(z)=\int_0^\infty\frac{\sinh zx}{\sinh x}\,dx\qquad(z\in\mathbb{C},|\Re z|<1)$$ can be evaluated using the residue theorem (like this), or like this: \begin{align} f(z)&=\int_0^\infty(e^{zx}-e^{-zx})\frac{e^{-x}}{1-e^{-2x}}\,dx=\sum_{n=0}^{\infty}\int_0^\infty(e^{zx}-e^{-zx})e^{-(2n+1)x}\,dx\\&=\sum_{n=0}^{\infty}\left(\frac{1}{2n+1-z}-\frac{1}{2n+1+z}\right)=\sum_{n=0}^{\infty}\frac{2z}{(2n+1)^2-z^2}\\&=-\frac{d}{dz}\sum_{n=0}^{\infty}\ln\left(1-\frac{z^2}{(2n+1)^2}\right)=-\frac{d}{dz}\ln\cos\frac{\pi z}{2}=\color{blue}{\frac{\pi}{2}\tan\frac{\pi z}{2}}. \end{align} By $\sinh(iz)=i\sin z$ and product-to-sum formulae for $\sinh$/$\cosh$, your integral is equal to $$-\frac{1}{4a}\left(f\Big(\frac{x+i(y+\tau)}{a}\Big)+f\Big(\frac{x-i(y+\tau)}{a}\Big)-f\Big(\frac{x+i(y-\tau)}{a}\Big)-f\Big(\frac{x-i(y-\tau)}{a}\Big)\right).$$ It remains to simplify this expression...
metamorphy
  • 39,111
  • Thanks. I remember when I convert them into exponential functions, and convert to geometric sums and finally get an infinite sum, with coefficients similar to your last row...But the infinite sun does not seem solvable. – Daydream Sep 11 '19 at 17:00
