When considering a second order differential equation, say: $$\frac{d^2y}{dx^2} = 10$$ is it possible to separate and integrate such? Separating the variables results in: $$d^2y = 10 dx^2$$ and integrating results in: $$y dy = 10xdx$$and then integrating once again results in: $$\frac{y^2}{2} = 5x^2$$ Clearly solving for $y$ would yield something which is not the correct answer. I considered the scenario where the integral of $d^2y$ would be $dy$, but if that is the case why is the integral of $10dx^2$ = $10xdx$?
5 Answers5
$$\frac{d^2y}{dx^2} = 10$$ $d^2y = 10 dx^2$ is non-sens because $\frac{d^2y}{dx^2}$ is not a fraction but is a conventional symbol meaning that the function $y(x)$ is differentiated two times successively.
A more comprehensive writing is : $$\frac{d}{dx}\left(\frac{dy}{dx}\right)=10$$ Then you can separate : $$d\left(\frac{dy}{dx}\right)=10dx$$ Which is integrated as : $$\frac{dy}{dx}=10x+c_1$$ $$dy=(10x+c_1)dx$$ And integrated again : $$y=5x^2+c_1x+c_2$$
JJacquelin
  • 66,221
  • 37
  • 87
  • Ah, this makes sense. I appreciate it a lot, thanks! Is there a reasoning why dy/dx can be treated as a separable fraction, however? – CanadianArcade Aug 31 '19 at 19:35
  • In a few words limited by the size of a comment, one cannot treat rigorously the basic of differential calculus. A key is the notion of infinitesimals conventionally noted $dx$ , $dy$, … which are smaller than any real number ( in absolue value of course). There are several methods to rigorously relate $dy$ and $dx$ to the notion of derivative of a function $y(x)$. https://en.wikipedia.org/wiki/Infinitesimal ; https://en.wikipedia.org/wiki/Differential_calculus . – JJacquelin Aug 31 '19 at 20:57
I think the "separable" concept does not apply to second order equations. I think you'd have a hard time getting a correct solution of $${d^2y\over dx^2}=y$$ by separation of variables.
Gerry Myerson
  • 179,216
The correct difference equation is $$ y(x+dx)-2y(x)+y(x-dx)=(d^2y)(x)=10(dx)^2 $$ This can be solved as any other difference equation. The left side has as characteristic roots $1$ as a double root, which is in resonance with the constant term on the right side, so you get as solution of the inhomogeneous difference equation $$ y(x+n\,dx)=A+Bn+Cn^2. $$ Inserting this for $n=-1,0,1$ gives \begin{align} A&=y(x),\\ 2B&=y(x+dx)-y(x-dx)=2y'(x)\,dx,\\ 2C&=y(x+dx)-2y(x)+y(x-dx)=10(dx)^2, \end{align} so that $$ y(x+n\,dx)=y(x)+y'(x)\,(n\,dx)+5\,(n\,dx)^2 $$ or $$ y(x)=y(x_0)+y'(x_0)(x-x_0)+5(x-x_0)^2. $$
Lutz Lehmann
  • 126,666
Think of
$$ y'y'' = 10 y' $$
or
$$ \frac 12\frac{d}{dx}(y')^2 = 10\sqrt{(y')^2} $$
now separating variables
$$ \frac 12\frac{d\eta}{\sqrt{\eta}} = 10 dx $$
and after integration
$$ \sqrt \eta = 10 x + c_1 = y' $$
and finally
$$ y = 5 x^2+c_1 x+ c_2 $$
Cesareo
  • 33,252
Let's proceed appropriately: We have $\mathrm d\mathrm d y=\mathrm{d^2}y=10\mathrm d x^2=(10\mathrm d x)\mathrm d x.$ Integrating gives $\mathrm d y=(10x+a)\mathrm d x.$ Integrating again gives $$y=5x^2+ax+b,$$ as wanted.
Allawonder
  • 13,327
