My book is Connections, Curvature, and Characteristic Classes by Loring W. Tu (I'll call this Volume 3), a sequel to both Differential Forms in Algebraic Topology by Loring W. Tu and Raoul Bott (Volume 2) and An Introduction to Manifolds by Loring W. Tu (Volume 1).
I refer to this page.
Conventions for the question (See this post which forms the basis for these conventions):
A. I consider manifolds as manifolds with boundary with empty boundary. Thus, with $M$ a "manifold with boundary", $\partial M$ could be empty.
B. "Manifold with boundary" means "Manifold with boundary with dimension". Objects like $[0,1) \cup \{2\}$ are manifolds with boundary with no (uniform) dimension.
Question 3. Should I interpret the following sentence
"This example shows that the image of a smooth nonregular curve need not be smooth" $\tag{A}$
as
"...need not be a smooth immersed submanifold with boundary" $\tag{B}$
rather than either of the following?
"...need not be a smooth regular/embedded submanifold with boundary" $\tag{C}$
or "...need not be a smooth manifold with boundary" $\tag{D}$
Explanation of the question:
3.1. $(A)$ suggests that
- "The image of a smooth regular curve is smooth." $\tag{E}$
3.2. Since regular parametrized curves are equivalent to immersed parametrized curves, images of smooth regular curves are
3.2.1. necessarily immersed submanifolds with boundary
3.2.2. not necessarily regular/embedded submanifolds with boundary
3.2.3. not necessarily manifolds with boundary.
3.3. A regular curve $c$ is an embedding if the image is a 1-submanifold with boundary (or 1-manifold with boundary. I'm not really sure) with non-empty boundary or equivalently if $c$ is injective. (See here)
3.4. By (3.2) and (3.3), I think either that
3.4.1. $(E)$ is what is meant and that "is smooth" should be interpreted as "is a smooth immersed submanifold with boundary"
3.4.2. $(E)$ is what is meant and that "is smooth" is interpreted as "is a smooth regular/embedded submanifold with boundary". If this is the case, then I not only find it weird that we don't have an immersed submanifold with boundary for an example but also think this is wrong unless injective is somehow included in the definition of regular.
3.4.3. $(E)$ is not what is meant. In this case, I find "This example shows that the image of a smooth nonregular curve need not be smooth" pointless. I think $(E)$ is what is meant.
Related, I think: Are geometric curves immersed submanifolds with boundary, manifolds with boundary or neither?
