16
In my (limited) experience, it is usually easy to see when something is large enough to be a proper class, by constructing an element of the class for every set.
However, sometimes such a proper class has lots of redundant information, so we consider it modulo some equivalence relation. This way, in some cases, we end up with something small enough to be (represented by) an actual set!
Motivating example: The Witt group $W(F)$
(actually, we don't care about the group structure, I'm sorry)
Let $F$ be a field. Let $$ W(F) := \{(V, q)\ \text{quadratic}\ F\!-\!\text{vector spaces}\}/\sim $$ Where $(V, q)\sim (W, r)$ if there exist metabolic (i.e., hyperbolic plus degenerate) spaces $E_1, E_2$ such that $(V, q)\perp E_1 \simeq (W, r)\perp E_2$, where $(V, q)\perp (W,r) = (V\oplus W, (v,w)\mapsto q(v)+r(w))$.
Then $W(F)$ is a set has a set of representatives.
When I first learned this, this was not at all obvious to me.
(To be honest, I only vaguely recall this, and am not too sure of the technical details. The gist of this was however, that we only consider finite-dimensional vector spaces in the first place, which allow only for a finite number of non-equivalent quadratic forms, and even after that, most of those can be seen to be equivalent to a quadratic space of lower dimension by adding elements to make a large portion look hyperbolic)
Question
So, in a similar spirit to this question:
What are other non-obvious examples of sets, e.g. proper classes being “quotiented” to a set?
    The big one is localization in homotopy theory (or more broadly, (model) category theory). Entire structures are invented just to make sure that hom-sets are truly sets and not classes. – Randall Jul 29 '19 at 14:57
    Neat question! $;;$ – Dave L. Renfro Jul 29 '19 at 15:02
    I don't know if this counts, since it is not an example of a class being quotiented, but in set theory one defines, for an infinite cardinal $\kappa$, $H(\kappa)={x\mid |\mathrm{trcl}(x)|<\kappa}$ and it is not immediately obvious that this is a set. (One usually proves $H(\kappa)\subseteq V_\kappa$ to establish that) – Alessandro Codenotti Jul 29 '19 at 15:02
  • @AlessandroCodenotti what is $\operatorname{trcl}(x)$? – Lukas Juhrich Jul 29 '19 at 15:07
  • The transitive closure of $x$, there are a few equivalent definitions, for example it is the smallest transitive superset of $x$ – Alessandro Codenotti Jul 29 '19 at 15:08
  • @AlessandroCodenotti thanks for clarifying. My intention was not only about quotient constructions, so I edited accordingly. I just thought these would probably be most prevalent in this context. – Lukas Juhrich Jul 29 '19 at 15:11
    You are confusing the quotient with "there is a set of representatives". – Asaf Karagila Jul 29 '19 at 17:13
  • As Asaf points out, usually what happens is that you have a proper class and an equivalence relation for which the class has a set of representatives. As for "obviously" it depends on what background you have. Would you consider obvious that given an algebraic theory and a cardinal $\kappa$ there are set-many "isomorphism classes" (in the previously described snese) of models of that theory ? With a tad of experience it becomes clear, but to a newcomer it might not be obvious. Or same question for isomorphism classes of manifolds (where my definition of manifold includes second countable) – Maxime Ramzi Aug 06 '19 at 18:18
  • @Max no, I would not consider that obvious. As the audience, consider someone who has not attended a comprehensive course on set theory, but knows most of the basic terminology (what a cardinal is, how ordinals are constructed), similarly for model theory. – Lukas Juhrich Aug 06 '19 at 18:24
  • The category of finitely generated modules over a commutative ring $R$ is essentially small(if I'm not making a huge mistake.). Since any module is a quotient of a free module and if I'm remembering correctly you can take that free module to be f.g. as well (when the module you started with was f.g. too.) and then any f.g. module would be isomorphic to a quotient of a f.g. free module. But all the f.g. free modules over $R$ are of the form: $R^n$, for some $n \in \omega$, so they have set many quotients. – Shervin Sorouri Aug 07 '19 at 07:41
Consider compact metrizable topological spaces, modulo homeomorphism there's actually set many such spaces.
One way to show this is to show that for every compact metrizable space $X$ there is an embedding $X\to [0,1]^\Bbb N$, so there are at most $|\mathcal P([0,1]^\Bbb N)|=2^{|[0,1]^\Bbb N|}=2^\mathfrak c$ such spaces.
Based on the comments (in particular, when I say "isomorphism classes of ... form a set", what I really mean is "there is a set such that any ... is isomorphic to one element of this set"; or I could argue that what I say makes sense using Scott's trick : this all should be equivalent anyway), here are some examples :
1- Given a cardinal $\kappa$, a first order language $L$ and a theory $T$ in $L$, the isomorphism classes of models of $T$ form a set. An interesting special case is when you take $L$ to consist entirely of function symbols and $T$ a list of universally quantified equations; then knowing that this is a set actually helps in one of the usual proofs of the Birkhoff variety theorem.
It's important to note that I restricted to a first order language, but actually there's no need for symbols in $L$ to be finitary, as long as $L$ is a set (and so its symbols have bounded (possibly infinite) arity), this works and the proof is the same.
2- If you include "second countable" in the definition of manifold (I don't know how consensual that is, my teachers did it that way), then diffeomorphism classes of manifolds form a set. This can be interesting to know in some considerations where we have functors defined on $\mathrm{Diff}$, and so to deal with functor categories, knowing that this category is essentially small is interesting (e.g. to see that prestacks on $\mathrm{Dif}$ actually form a category, or cobordism categories)
3- Given a cardinal $\kappa$, homeomorphism classes of compact Hausdorff spaces of cardinality $\leq \kappa$ form a set. This follows because the topology on a compact Hausdorff space is completely determined by the $\lim$ function $\beta X\to X$ ($\beta X$ is the set of ultrafilters on $X$). I don't know how useful that is, but I used it (rather a trivial variation of it) in a bachelor project to prove the existence of a universal minimal flow of a topological group.
4- (part of ) 1- and 3- generalize cleanly to monadic categories : whenever a category of objects is equivalent to $\mathbf{Set}^T$, the Eilenberg-Moore category of $T$-algebras for a certain monad $T$, then for any cardinal $\kappa$ there is a set of isomorphism classes of objects of this category of cardinality $\leq \kappa$. In 1-, $T$ is the monad associated to an algebraic theory, in 4- $T$ is the ultrafilter monad.
One can modify slightly 4 (or 1) to get that isomorphism classes of "finitely generated stuff" usually form a set : $R$-modules for any ring $R$ for instance.
5- Homeomorphism classes of separable metric spaces (in fact, isometry classes of separable metric spaces) form a set. In fact, with the ultrafilter trick as above, given a cardinal $\kappa$, homeomorphism classes of Hausdorff spaces that have a dense subset of size $\leq \kappa$ form a set.
6- As Randall pointed out in the comments, given a model category $C$ and objects $X,Y\in C$ it is not clear at all that $\hom_{\mathbf{Ho}(C)}(X,Y)$ should be a set. In fact if we don't take a model category but just a category with weak equivalences and localize, in general these don't form sets. But in a model category, fibrant and cofibrant replacements and various lemmas ensure that $\hom_{\mathbf{Ho}(C)}(X,Y)$ is (isomorphic to) a quotient of a hom-set in $C$ and is therefore essentially a set.
7- An example that is not "isomorphism classes of", that is also a bit weird, but that has some interesting (philosophical) implications : the class of all sets $x$ such that $\neg\mathrm{(Fermat's\, last\, theorem)}$ is a set (known since the 90's only !)
Maxime Ramzi
  • 43,598
  • 29
  • 104
