My book is Connections, Curvature, and Characteristic Classes by Loring W. Tu (I'll call this Volume 3), a sequel to both Differential Forms in Algebraic Topology by Loring W. Tu and Raoul Bott (Volume 2) and An Introduction to Manifolds by Loring W. Tu (Volume 1).
I refer to Section 2.1, Section 2.2, Volume 1 Section 8.6 (Part 1) and Volume 1 Section 8.6 (Part 2).
Use $t$ to denote the standard coordinate on $[a,b]$, and use $t_0$ to denote a point in $[a,b]$. Let $x$ be the standard coordinate on $[0,l]$. The speed of a curve $c: [a,b] \to M$ into a Riemannian manifold $M$ at a point $t_0 \in [a,b]$ is defined $\|c'(t_0)\| := \sqrt{\langle c'(t_0), c'(t_0) \rangle_{t_0}}$. Then we can define speed as a map by $\|c'\|: [a,b] \to [0, \infty), (\|c'\|)(t_0) := \|c'(t_0)\|$. Here, it seems to be claimed that this map $\|c'\|$ is the derivative of arc length function $s$ of $c$.
Question: In the first place, is $c$ supposed to be assumed regular/an immersion for the definition of speed $\|c'\|$, arc length $l$ or arc length function $s$, and why/why not?
My thoughts:
If $c$ is regular/an immersion, then $\|c'\|$ is smooth by this, but I think it's possible to define $\|c'\|$, $l$ and $s$ for continuous $\|c'\|$. I can't think of a condition on $c$ to make $\|c'\|$ continuous but not necessarily smooth (see thought (2) below).
- 1.1. Edit: I actually didn't mention earlier: Observe that in the paragraph before Proposition 2.3, Tu uses the fundamental theorem of calculus. Based on the version of FTC on Wikipedia, I think the rule behind FTC is something like
- "continuous $\mathbb R$-valued functions defined on a closed interval $[a,b]$ of $\mathbb R$ are Riemann integrable on $[a,t]$ for any $a<t\le b$"
- Without such rule, I don't think we can define the "$F$" in the version of FTC on Wikipedia. With such rule, if $\|c'\|$ (the "f") were continuous, then we could define $s$ (the "F") and thus define $l$. If $c$ is regular/an immersion, then $\|c'\|$ is smooth and thus continuous. If $c$ were irregular/not an immersion, then $\|c'\|$ is not necessarily smooth, I think (see thought (2) below). But we can still define $s$ (and thus define $l$) by the rule if $\|c'\|$ is somehow at least continuous.
It could be possible $\|c'\|$ is actually continuous or even smooth for an irregular/a non-immersion, but still smooth, $c$ because in this question, Paulo Mourão can prove the smoothness part without immersion.
Update: I think we can still define $\|c'\|$, $l$ and $s$ for an irregular/a non-immersion $c$ because there's this exercise: Exercise 2.6, which asks for the arc length of a parametrized curve that was shown in Example 2.2 (see here) to be irregular/not an immersion. At the very least $l$ and $\|c'\|$ are defined. Not sure if $s$ is.
Context:
