I would appreciate if somebody could help me with the following problem:
Q: find $a_n=?$
$$a_{n+1}=\frac{1}{2}\left(a_n+\frac{1}{a_n}\right)(n=1,2,3,\cdots),~a_1=2$$
There are quite a few posts on the main site concerning convergence of this sequence, for example, Calculating square roots using the recurrence $x_{n+1} = \frac12 \left(x_n + \frac2{x_n}\right)$ and more generally Calculating square roots using the recurrence $x_{n+1} = \frac12 \left(x_n + \frac2{x_n}\right)$. So from those posts we know that it converges to $\sqrt2$. But finding the $n$-th term is a slightly different task from finding the limit.
Young
  • 5,492
Rewrite $a_n$ as $\frac{p_n}{q_n}$ for two sequences $p_n, q_n$ that need to be determined. We have:
$$a_{n+1} = \frac12 ( a_n + \frac{1}{a_n} ) \iff \frac{p_{n+1}}{q_{n+1}} = \frac{p_n^2+q_n^2}{2p_nq_n}$$
We can choose $p_{n+1} = p_n^2 + q_n^2$ and $q_{n+1} = 2p_nq_n$ and get:
$$ p_{n+1} \pm q_{n+1} = ( p_n \pm q_n )^2 \implies p_{n} \pm q_{n} = (p_1 \pm q_1)^{2^{n-1}}$$ Since $a_1 = 2$, we take $p_1 = 2, q_1 = 1$ to get:
$$ p_{n} + q_{n} = 3^{2^{n-1}} \text{ and } p_{n} - q_{n} = 1$$ This leads to
$$ a_{n} = \frac{p_n}{q_n} = \frac{3^{2^{n-1}}+1}{3^{2^{n-1}}-1}$$
achille hui
  • 122,701
This is the sequence generated by using Newton's method to find square roots, i.e.,
$$\lim_{n \rightarrow \infty} a_n = \sqrt{1} = 1$$
Anyway, consider the following identity:
$$\coth{2 t} = \frac{1}{2}\left ( \coth{t} + \frac{1}{\coth{t}}\right)$$
Then let $a_n = \coth{t_n}$. The recurrence becomes
$$t_{n+1} = 2 t_n$$ $$t_1 = \text{arccoth}(2)$$
Then the solution to the recurrence is
$$a_n = \coth{\left ( 2^{n-1} \text{arccoth}(2)\right )} $$ where
$$\exp{[\text{arccoth}(2)]} = \sqrt{3}$$
so that
$$a_n = \frac{3^{2^{n-1}}+1}{3^{2^{n-1}}-1}$$
Ron Gordon
  • 138,521
