I want to know if the following is correct:
If $G$ is abelian, then is trivial since any subgroup is normal and because of Lagrange, it has an element of order $p$.
If $G$ is not abelian, then, I can supose $q > p$, so, Sylow says that $n_p | q^2$, $n_p \equiv 1(p)$, $n_1 | p^2$, $n_q \equiv 1(q)$, so $n_q =1$ or $n_q = p^2$, since if $n_q=p$, it can't happen that $n_q \equiv 1(q)$.
If $n_q = 1$ then $G$ is not simple. Otherwise, $n_q = p^2$, so $p^2 \equiv 1(q)$, so $q | p^2-1 = (p-1)(p+1)$. Since $q$ is prime, this means that $q|p-1$ or $q|p+1$. But it can't be that $q|p-1$ for the same reason as before. So $q|p+1$. But the only primes that can accomplish this are $p=2$ and $q=3$. So I'm left with the case that $|G|=36$, but this is a case I already know from before that is not simple.
Is this correct?
Thanks
